How can I send a Task Request using vCalender/vTodo format using C#
I am writing an application where it should be able to send an email as a task request and it should be added to the Outlook task list and as well as in to the email list. But here according to the codings I have done the email is sent properly but it is not added to the task list. It is going as just an email. I have used vCalender/vTODO components to create the structure of the Task request even though the specified component is vTODO the task request is send as an email.
Here I have attached my cording.
If anyone knows the solution for this please help.
private string CreateTask(DateTime start, DateTime end, String body, String sub, String status)
StringBuilder sbvCalender2 = new StringBuilder();
sbvCalender2.Append("METHOD: REQUEST");
sbvCalender2.Append("\n");
sbvCalender2.Append("BEGIN:VCALENDAR");
sbvCalender2.Append("PRODID:-//ABC Corporation//NONSGML My Product//EN");
//sbvCalender2.Append("BEGIN:VTODO");
sbvCalender2.Append("BEGIN:VEVENT");
sbvCalender2.Append("SEQUENCE:2");
sbvCalender2.Append("UID:uid4@host1.com");
sbvCalender2.Append("ORGANIZER:MAILTO:manula.m@eyepax.com");
sbvCalender2.Append("DUE:20110415T235959");
sbvCalender2.Append("STATUS:NEEDS-ACTION");
sbvCalender2.Append("SUMMARY:Kolkata Kinght Riders");
sbvCalender2.Append("BEGIN:VALARM");
sbvCalender2.Append("ACTION:AUDIO");
sbvCalender2.Append("TRIGGER:19980403T120000");
sbvCalender2.Append("ATTACH;FMTTYPE=audio/basic:http://example.com/pub/audio-files/ssbanner.aud");
sbvCalender2.Append("REPEAT:4");
sbvCalender2.Append("DURATION:pT1H");
sbvCalender2.Append("END:VALARM");
//sbvCalender2.Append("END:VTODO");
sbvCalender2.Append("END:VCALENDAR");
MessageBox.Show(sbvCalender2.ToString());
return sbvCalender2.ToString();:confused:
Thank you very much for your information. Hope they will be more helpful for my question.
Regards
Manula.
M How can I send task request using vCalender/VTodo component using C# Using Outlook 2
Z Item.Recipients for Task Assignment on Send Outlook VBA and Custom Forms 10
E Send a Reminder/Task to certain Email Recipient Using Outlook 5
Diane Poremsky Send a Task Status Report Using Outlook 0
S How to send an OUTLOOK task to a contact out of my active directory? Using Outlook 2
M Send email on task creation? Using Outlook 2
A Send Email to Task while sending to Email address Outlook VBA and Custom Forms 1
K send email when task changes Outlook VBA and Custom Forms 3
TomHuckstep Remove Send/Receive All Folders (IMAP/POP) button from Outlook 365 Ribbon Using Outlook 1
T Outlook 2010 recipient no longer shows in 'Send To' Using Outlook 0
Geldner Tweak Junk Email Reporting tool to default to particular email on send? Using Outlook 3
Geldner Send / Receive a particular group via macro or single keypress Using Outlook 1
F Send As a Gmail account via outlook Web Using Outlook 3
