Install problem with no Error Message
  • Thread starter Thread starter Dian
Dian
When I try to install the BCM for outlook 2007, the install runs then at the
end says it can not install and view the log file "MBSsetuptmp2B7.log". The
last line in the rather long log says "MainEngineThread is returning 0". I
am running on exchange. Suggestions?
Can you open up the log file , you should find it in the temporary folder
that can be accessed by going to start > run and type %temp%
Once you bring up the log search for return value 3 .
Regards
Rahul Thomas [MSFT]
The posting is provided "AS IS" with no warranties and confers no rights.
https://blogs.msdn.com/rathomas
"Dian" <Dian> wrote in message
news:60B3DEF8-128E-4102-B48A-EA090D88E8A6@microsoft.com...
> the
> The
> I
"Returning 0" usually means that part worked.
I recall that after installing the MSI (the action that generates
MBSsetuptmpXXX.log files), setup tries to configure somethings, and if
that fails, setup incorrectly indicates the MSI log file. See if there
there is another log file in the minute after MBSsetuptmp2B7.log. That
may contain the actual error. Seup may be trying to configure the sql
service so that BCM can use it. Check to see if the sqlserver MSSMLBIZ
Windows service is running. If not, start it and run BCM setup again.
C VBA problem in new install Using Outlook 3
D BCM install problem on Win7 BCM (Business Contact Manager) 3
M Install problem on Windows 7 BCM (Business Contact Manager) 2
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
e_a_g_l_e_p_i I can't believe what I am seeing when trying to install Outlook 2021 Using Outlook 9
R Unable to install without email account Using Outlook 4
J Install BCM Client without an local SQl Database BCM (Business Contact Manager) 6
Chris Grew How Long To Install BCM BCM (Business Contact Manager) 2
icacream reinstall outlook after new install win7 Using Outlook 2
R Cannot Install Outlook Invalid XML Using Outlook 2
B OL2010 and install custom WYWO form Using Outlook 1
D 2013 BCM Won't Install BCM (Business Contact Manager) 1
S Recover Autocomplete After Computer Failure Re-install Using Outlook 3
T Office2013 and BCM on Windows 8.1 -- install of BCM does not work? BCM (Business Contact Manager) 2
A how to install or enable categories in OL 2013 for calendar and contacts Using Outlook 5
O RE-install of BCM and previous sync profile conflicts BCM (Business Contact Manager) 3
D Can't install here Using Outlook 3
J Office + Outlook 2013 installed, but I need to install Outlook 2010 Using Outlook 2
B Can't install Calendar Printing Assistant - Windows 7 64bit&Office 2010 32bit Using Outlook 2
S BCM Install Issues BCM (Business Contact Manager) 2
L Can't install contacts Using Outlook 2
L Cannot install BCM 2010-"Outlook 2010 Not Installed" but it is! BCM (Business Contact Manager) 1
T BCM Install fails Both w Off. Pro 2010 Beta & on reinstall Off.Pro BCM (Business Contact Manager) 5
T Install BCM on SBS 2008 Standard server BCM (Business Contact Manager) 1
M OL2007 Add-in won't install on OL2010 Outlook VBA and Custom Forms 1
D business contact manager did not install with outlook 7 BCM (Business Contact Manager) 2
S Trying to install BCM 2010 x64, getting error BCM (Business Contact Manager) 8
E Install BCM on windows 7 BCM (Business Contact Manager) 2
H Fail to install BCM 2007 (English) on Windows 7 64 bit (Danish) BCM (Business Contact Manager) 3
S Failed to install Business Conctact Manager 2007 BCM (Business Contact Manager) 1
R RE: Business Contact manager failed to install BCM (Business Contact Manager) 1
S Business Contact Manager 2007 won't install with Windows 7 BCM (Business Contact Manager) 3
D Win7 x64 - Outlook 2010Beta x64 - BCM 2010 x64 does not install BCM (Business Contact Manager) 1
T Can I install BCM on 2 computers w/o buying 2 copies? BCM (Business Contact Manager) 1
S BCM in Office Ultimate 2007 Won't Install on W7 Ultimate 32 BCM (Business Contact Manager) 1
K Unable to install business Contact Manager. BCM (Business Contact Manager) 1
M How do I install Outlook 2007 Business Contact Manager on Win7x64 BCM (Business Contact Manager) 1
A What to do if BCM didn't install with 2007 Professional Trial? BCM (Business Contact Manager) 1
J Install BCM on Windows Vista BCM (Business Contact Manager) 3
H Failed install BCM (Business Contact Manager) 2
S BCM install fails at SQL install BCM (Business Contact Manager) 1
M How to install custom mapi form programmatically? Outlook VBA and Custom Forms 1
