Active explorer issue
  • Thread starter Thread starter Ashish
Ashish
In Active inspector when open a mail, If add an attachment to a mail and
dont call Save function then this attachment will not update on exchange
server for this mail.
But In active explorer when select a mail we add attachment to a mail and
dont save save function. Attachment is updated on exchange server for this
mail. Is there any reason for that? Can we avoid saving? Outlook
version-2003
How are you adding an attachment in ActiveExplorer()? Is it with code or
from the UI. If using code show it.
In general you always have to save, possibly unless in-cell editing is
enabled and that affects automatically saving any changes. See if the Saved
property on the item has changed after you add the attachment in the
Explorer.
"Ashish" <akohli_2004@hotmail.com> wrote in message
news:e2xdzUmJKHA.4432@TK2MSFTNGP05.phx.gbl...
> version-2003
I'm adding attachment in code under explorer_viewchange event(when selecta
mail item). When i add attachment to a mail in ActiveExplorer->ViewChange
event, mail item save property returns false. But when i select another mail
item item and check Save property of previous mail item where i add
attachment then it returns true. It means that attachment is added on
exchange server.
How to use in-cell editing ?? Can we avoid saving if we add an attachment.
My user is exchange server user and has cached mode on.
//in c++ event number is 0xf007
Outlook::_MailItemPtr pMailItem = NULL;
Explorer_ViewChange()
if(pMailItem != NULL)//if we select an item before and already add
attachment to it
bool issaved = pMailItem->GetSaved(); //GetSaved return true
else
Outlook::SelectionPtr spSelections = ActiveExplorer->Selection;
if( spSelections)
int selecteditems = spSelections->Count;
if(selecteditems == 1)
pMailItem = spSelections->Item(1);
pMailItem ->Attachments->Add("c:/filename.txt");
return false
}//here i dont call pMailItem->save function
news:ONIzo6oJKHA.4004@TK2MSFTNGP05.phx.gbl...
> Saved property on the item has changed after you add the attachment in the
> Explorer.
> > this mail. Is there any reason for that? Can we avoid saving? Outlook
> > version-2003
Do you mean the ViewSwitch() event? There is no ViewChange() event. Why
aren't you using Explorer.SelectionChange(), that would be the correct event
to handle.
news:OkzUGxxJKHA.4004@TK2MSFTNGP05.phx.gbl...
> mail item item and check Save property of previous mail item where i add
> exchange server.
> attachment to it
> else
> if( spSelections)
> return false
Sorry it's explorer.selectionchange
it's call when i change selection on any mail/folder
news:%23QhFJ0xJKHA.1340@TK2MSFTNGP05.phx.gbl...
> event to handle.
> > selecta mail item). When i add attachment to a mail in
> > ActiveExplorer->ViewChange event, mail item save property returns false.
> > But when i select another mail item item and check Save property of
> > previous mail item where i add attachment then it returns true. It means
> > that attachment is added on exchange server.
> > attachment. My user is exchange server user and has cached mode on.
> > attachment to it
> > else
> > if( spSelections)
> > return false
If you want to know whether or not an item in a Selection is changed you
handle SelectionChange(). When that fires you get the new Selection. You can
then set up handlers for each item in the Selection and handle the
AttachmentAdd() event or the BeforeAttachmentSave() event or any other
attachment related event you want to track.
news:uG1ck8xJKHA.1252@TK2MSFTNGP04.phx.gbl...
So if i handle those attachment events and avoid saving then it will not
update on exchange server. But will it allow to add attachment to mail and
display in outlook when we select a mail?
news:egziUR%23JKHA.5956@TK2MSFTNGP03.phx.gbl...
> can then set up handlers for each item in the Selection and handle the
Why not try it and see?
news:eFcBT$%23JKHA.3632@TK2MSFTNGP05.phx.gbl...
i tried it but attachment still save on exchange server. I handle
beforeattachmentsave and addattachment and cancel the saving but attachment
still save on exchange server. I follow below link to avoid saving
http://codeidol.com/csharp/c-sharp-in-office/Working-with-Outlook-Events/Outlook-Item-Events/
To avoid saving when i select another mail i delete attachments from
previous mail and call save function. But this modify mail date. I want to
add attachment in mail without modifying its date.
news:eSlOLWCKKHA.4236@TK2MSFTNGP04.phx.gbl...
> > and display in outlook when we select a mail?
I'm afraid what you want can't be done. If you modify an item it will get
some date related fields also modified. Not much you can do about that.
news:%23T41tWvKKHA.4236@TK2MSFTNGP04.phx.gbl...
To modify item i'm only adding attachment for a selected item in outlook
explorer. And when select another item i delete attachment from previous
item where i add. All this i'm doing without saving item. But this action
save item on exchange server. But we can avoid this saving as below link
says that
My motive is to display attachments when select a item and delete them when
select another item. And this all should not modify on exchange server.
It it not possible?
news:udCKjVwKKHA.4168@TK2MSFTNGP05.phx.gbl...
> >attachment still save on exchange server. I follow below link to avoid
> >saving
> > to add attachment in mail without modifying its date.
I don't think what you want is possible, no. Not using the Outlook object
model anyway.
news:eK8qe8wKKHA.3424@TK2MSFTNGP02.phx.gbl...
> says that
> when select another item. And this all should not modify on exchange
> server.
> It it not possible?
oh. It means i need to change my design again. To complete my task there is
one more way. I am adding an empty attachment to a mail on exchange server
using CDO. But when i see this mail in outlook/owa, i found attachment size
is change. it's 4 bytes or 64 bytes or 128 bytes. Dont know why but outlook
shows its size. I think if attachment size is 0 bytes then outlook will not
display it in right pane. When i open this attachment in outlook it has no
data. Can i hide this attachment? Means it should not display in right pane
when i select this mail in active explorer. Using CDO when i add this
attachment on exchange server i did not find any way to hide it. So i try in
outlook. I'm using following code to hide it in outlook. Code execute when
click on a mail(which has empty attachment) in active explorer.
Suppose mail item has one empty attachment
LPMESSAGE lpMessage = (IMessage*)(IUnknown*)
mailitem->Attachments->Item(1)->MAPIOBJECT;
SPropValue pProp;
pProp.ulPropTag = PR_ATTACHMENT_HIDDEN;
pProp.Value.b = true;
HRESULT hr = HrSetOneProp(lpMessage, &pProp);
if(hr == S_OK)
lpMessage->SaveChanges(FORCE_SAVE);
Also i have tried to change other properties like PR_ATTACH_METHOD,
PR_ATTACH_FILE_NAME etc. but nothing happed. I have tried not to use
SaveChanges method but no result.
news:O%233u6bxKKHA.3708@TK2MSFTNGP02.phx.gbl...
> model anyway.
> > says that
> > server.
> > It it not possible?
Take a look at the Redemption oriented discussion at
http://www.devnewsgroups.net/group/microsoft.public.office.developer.outlook.vba/topic37406.aspx
for information about using that property.
news:eFSE2MGLKHA.4432@TK2MSFTNGP05.phx.gbl...
> is one more way. I am adding an empty attachment to a mail on exchange
> server using CDO. But when i see this mail in outlook/owa, i found
> attachment size is change. it's 4 bytes or 64 bytes or 128 bytes. Dont
> know why but outlook shows its size. I think if attachment size is 0 bytes
> then outlook will not display it in right pane. When i open this
> attachment in outlook it has no data. Can i hide this attachment? Means it
> should not display in right pane when i select this mail in active
> explorer. Using CDO when i add this attachment on exchange server i did
> not find any way to hide it. So i try in outlook. I'm using following code
> to hide it in outlook. Code execute when click on a mail(which has empty
> SPropValue pProp;
> if(hr == S_OK)
Thanks it's the example to use extended mapi in outlook addin which ask to
save mail and attachment after setting property.
Is there any example to set this property using CDO? I tried but could not
get succeed.
news:OmcVl0JLKHA.4376@TK2MSFTNGP03.phx.gbl...
> > bytes then outlook will not display it in right pane. When i open this
> > it should not display in right pane when i select this mail in active
> > code to hide it in outlook. Code execute when click on a mail(which has
>> SPropValue pProp;
> > if(hr == S_OK)
I have no idea about any examples using CDO, you can google and see if you
can find anything and you can check at www.cdolive.com and see if anything's
there. If there are any I'd imagine they'd be in VB and not in C++.
news:OiwZsPKLKHA.5732@TK2MSFTNGP03.phx.gbl...
> get succeed.
P Automate Outlook Start - No Active Explorer Object Found Using Outlook 10
S Active Directory Management Tools for Administrators Using Outlook 0
Diane Poremsky Import Images into the Active Directory Using Outlook 0
S How to send an OUTLOOK task to a contact out of my active directory? Using Outlook 2
E Outlook rule only active certain times of day Using Outlook 6
R HELP!!! Email template with active excel spreadsheet Using Outlook 1
C Active Directory does not exist or cannot be contacted Exchange Server Administration 12
T Exchange 2010 servers can't communicate with Active Directory Exchange Server Administration 4
L VBA Processing of Active E-Mail Message Outlook VBA and Custom Forms 2
A active inspector in memory Outlook VBA and Custom Forms 1
M How to get active inspector window handle? Outlook VBA and Custom Forms 3
A disable a menu in active inspector Outlook VBA and Custom Forms 1
K Working with Explorer.Close event Outlook VBA and Custom Forms 3
R Sending emails via Outlook XP, from Windows 10 File Explorer Using Outlook 1
K Macro Not Executing then send email from Explorer Outlook VBA and Custom Forms 3
I Windows 10 - .msg files on disk show Explorer popup error Using Outlook 5
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
oliv- How to select an mailitem in explorer with "show as conversation" Outlook VBA and Custom Forms 8
Michael Chiasson PST file shows 300+MB in Windows Explorer, but only 250kb in Outlook 2010 Using Outlook 1
A vb6 run time error 5 when Outlook 2007 Explorer object displayed Outlook VBA and Custom Forms 1
C Create a Ribbon for the OL2010 Explorer Outlook VBA and Custom Forms 1
E Can I hide an explorer or make an explorer modal Outlook VBA and Custom Forms 2
S How to italicize the email entry in explorer window Outlook VBA and Custom Forms 3
T Creating toolbar in new Explorer Outlook VBA and Custom Forms 3
S Strange Behaviour of Explorer Object. Outlook VBA and Custom Forms 1
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
R destroying Explorer object pointers on shutdown Outlook VBA and Custom Forms 2
U Not able to delete Add-in button from multiple Outlook Explorer Outlook VBA and Custom Forms 1
C Solving the "indexing never finishes" issue Using Outlook 8
Z Hotmail account deleted from outlook and issue with account not exist Using Outlook 0
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
A Clipboard Resize Issue Using Outlook 7
D hide messege issue Using Outlook 1
