Time calculation problem
  • Thread starter Thread starter bear
bear
One field with time is being deducted from another field with time:
I have 3 fields in a custom form:
Start1
End2
Difference
Difference field has a formula: [End2] -[Start1]
Problem:
As long as time in field End2 and Start1 are not 12:00-12:59 am or pm formula work fine so 2pm-12pm = 2 hours
If I have 12:59 pm - 12:00 pm outcome is 12:59?
Please help
See if the DateDiff function is available in a formular field, for instance:
= DateDiff("h", [end2], [start1])
Best regards
Michael Bauer
Am Fri, 30 Oct 2009 12:15:48 -0400 schrieb bear:
> Start1
> End2
> Difference
> Problem:
> Please help
Hello
Tried DateDiff("h", [end2], [start1]). Did not work, it is constantly shows 5:00 regardless of what is in end2 and start1?
Please help
mb wrote on Tue, 03 November 2009 15:19
> > Best regards
> Michael Bauer
> > Start1
> > End2
> > Difference
> > Problem:
> > Please help
With Debug.Print you can print the values of end2 and start1 (ctrl+g). I
doubt they really change.
Best regards
Michael Bauer
Am Thu, 17 Dec 2009 18:14:09 -0500 schrieb bear:
> Hello
> Please help
instance:
>> > > Best regards
> > Michael Bauer
>>> Start1
> >> End2
> >> Difference
>>> Problem:
>>> Please help
S Perform calculation in task fields Outlook VBA and Custom Forms 1
