Re: Problem wit deploying Outlook Add-in
  • Thread starter Thread starter Ken Slovak - [MVP - Outlook]
K
What Outlook PIA does it reference? Where it fails is the same version of
Outlook deployed? Do you check for PIA's, Framework and Extensibility?
Is this a shared addin or VSTO?
You need to provide complete information if you want help.
Also, see the troubleshooting article and the information about the Fusion
loader at
http://blogs.msdn.com/vsod/archive/2008/04/22/Troubleshooting-com-add-in-load-failures.aspx.
If all else fails that can tell you what's not loading.
"escamoteur" <mail@burkharts.net> wrote in message
news:FAC3C123-E57C-413D-BED4-8BEB7462C9BF@microsoft.com...
> Hi,
> I have my first .net Outlook Add-In (Beta) finished and it runs great on
> my machine. I wanted to give it some friends for testing but it fails to
> run.
> It reports a COM-Error when trying to activate it.
> So it get's installed correctly, all registry settings are there. I guess
> it's a missing COM object or wrong version of the .net
> framework. How can I figure out what the problem is?
> When I try to install it on a fresh Windows Vista or Windows 7 System with
> just Office 2007 SBE everything works fine.
> Best
> Tom
Thanks a lot for the Pointer:
@Ken: I didn't know which information is need, otherwise I would have provided it at the first post.
What I don't understand that it runs with two clean installations without any Updates installed.
But I will check everything you mentioned first
Best
Tom
<kenslovak@mvps.org> schrieb im Newsbeitrag news:eILiAN0WKHA.1268@TK2MSFTNGP04.phx.gbl...
> loader at
> > Hi,
> > run.
>> Best
> > Tom
E Problem wit deploying Outlook Add-in Outlook VBA and Custom Forms 3
Marc2019 Outlook 2016 Font Problem Using Outlook 4
