Problem with a Search-Object resulting from an AdvancedSearch
progger
I have a Sub "FindAndSendAppointments()" searching through Outlook Calendar using AdvancedSearch-method. Then I edit each found calendar item to be an appointment, save it and finally send it through e-mail.
The save causes the returned Search-Object from the AdvancedSearch to change because the calendar item does not meet the search criteria anymore and thus I'm having troubles looping through this always changing Search-Object.
Here is the code, hope it helps:
Option Explicit
Public m_SearchComplete As Boolean
Private Sub Application_AdvancedSearchComplete(ByVal SearchObject As Search)
   If SearchObject.Tag = "MySearch" Then
       m_SearchComplete = True
Sub FindAndSendAppointments()
   Dim Scope As String
   Dim Filter As String
   Dim MySearch As Outlook.Search
   Dim lCounter As Long
   Dim myItem As Object
   Dim myRequiredAttendee As Outlook.Recipient
   m_SearchComplete = False
   'Establish scope for default Calendar folder
   Scope = "'" & Application.Session.GetDefaultFolder(olFolderCalendar).FolderPath & "'"
   'Establish Filter, which finds all appointments containing "Test" in the subject
   'and which do not already contain the required attendee "test@test.com"
   Filter = _
   "(NOT" & Chr(34) & "urn:schemas:httpmail:displayto" & Chr(34) & " LIKE '%test@test.com%' AND NOT" & _
   Chr(34) & "urn:schemas:httpmail:displayto" & Chr(34) & " LIKE '%Test%' AND " & _
   Chr(34) & "http://schemas.microsoft.com/mapi/proptag/0x0037001f" & Chr(34) & " LIKE '%Test%')"
   Set MySearch = Application.AdvancedSearch(Scope, Filter, True, "MySearch")
   While m_SearchComplete <> True
       DoEvents
   Wend
   Set myItem = MySearch.Results.GetFirst()
   Do While Not myItem Is Nothing
       myItem.MeetingStatus = olMeeting
       Set myRequiredAttendee = myItem.Recipients.Add("Test (test@test.com)")
       myRequiredAttendee.Type = olRequired
       myItem.Save
       myItem.Send
       Set myItem = MySearch.Results.GetNext()
       MsgBox "Remaining items: " & CStr(MySearch.Results.Count)
   Loop
If the AdvancedSearch returns e.g. 3 objects, the loop works for the first 2 and then Set myItem = MySearch.Results.GetNext() will result in "Nothing", even if MySearch.Results.Count still returns the "1" remaining appointment.
How could I cope with the always changing Search-Object? Any ideas?
Thanks alot!
Best regards
progger
In a first loop you could just get the objects and store them in a
collection. Then iterate through the collection, and work that.
BTW: There's an AdvancedSearchComplete event. You might want to use that
instead of the While-Wend loop.
Best regards
Michael Bauer
Am Wed, 20 Jan 2010 17:08:47 -0500 schrieb progger:
> Hi
> Code:
> Option Explicit
Search)
> End If
> End Sub
> Dim Scope As String
> Scope = "'" &
subject
> Filter = _
AND " & _
"MySearch")
> DoEvents
> Wend
> myItem.Save
> myItem.Send
> Loop
> End Sub
> Thanks alot!
> Best regards
> progger
D Icloud Outlook 2010 Task/Reminder Search Problem Using Outlook 1
Marc2019 Outlook 2016 Font Problem Using Outlook 4
