Identify Read Recepits
Sanya Ibrahim
I am using Outlook 2007. In the NewMail event, is it possible to identify if
the MailItem is a read receipt?
Could someone help me?
Thanks in advance.
K
Ken Slovak - [MVP - Outlook]
Look for a MessageClass property that starts with "REPORT.IPM.Note" and ends
with "IPNRN" to identify a read receipt.
"Sanya Ibrahim" <Sanya Ibrahim> wrote in message
news:DA1472BA-391C-4563-9B69-28D21C3E01EE@microsoft.com...
> Hi,
> if
> Thanks in advance.
Sanya Ibrahim
Thanks for the reply.
Well, I am rather new to OutLook vba. Is it possible for you to give a
sample / example code?
Sanya
> > Hi,
> > if
> > Thanks in advance.
K
Well, for one thing I wouldn't use NewMail(). It doesn't tell you what was
received and it misses things. I'd use NewMailEx() instead, which supplies a
list of items received as a list of EntryID's.
Always use F2 to open the Object Browser and that lets you see all methods,
properties and events for all Outlook items. Then use the Help to see code
samples. In the case of Application.NewMailEx() the code sample shows how to
get an item from the collection of EntryID's. That item (mai) can be used
thusly to check the MessageClass:
If ((Left(mai.MessageClass, Len("REPORT.IPM.Note")) = _
"REPORT.IPM.Note") And (Right(mail.MessageClass, _
Len("IPNRN")) = "IPNRN")) Then
' this is a read receipt, do whatever
You should also become familiar with the www.outlookcode.com Web site, that
has code samples for almost anything Outlook related.
"Sanya Ibrahim" <SanyaIbrahim> wrote in message
news:0ABE7D91-1393-4B70-A5E7-A3200E894522@microsoft.com...
> Sanya
Sanya Ibrahim
Well, I tried it. I am getting into a strange situation wherein:-
(a) The EntryCollection argument has string values
(b) I split the EntryCollection string on "," and use the individual
EntryID strings to retrieve the mail Items
(c) However, the GetItemFromID(EntryID) returns nothing. The EntryID
argument is not null and the value does not correspond to the new inmail.
What to do?
> End If
> > Sanya
K
That is the correct procedure, and it has worked that way for me in the
past.
Are you using a StoreID argument? I'd try that and see if it helps. You can
get Inbox using NameSpace.GetDefaultFolder(olFolderInbox) and use the
StoreID property from that object.
Are you getting any exceptions or just nothing?
news:89F22C39-01A7-4F79-99C6-2E03B5EA0BFD@microsoft.com...
> What to do?
Sanya Ibrahim
I am using a storeID arguement. I am not getting any exception but the
MaiItem is showing as nothing.
Sanya
K
No idea. Similar code works here. Step the code in the debugger and see if
you can find out that way what the problem is.
news:5E8DDA27-BC43-42C9-9322-6DDE746BD848@microsoft.com...
> Sanya
I Identify Number of email messages opened Outlook VBA and Custom Forms 7
S VBA to identify a specific email and copy the attachment from it to the network Outlook VBA and Custom Forms 4
makinmyway How can I easily identify and delete from my contacts defunct email addresses? Using Outlook 2
G How can I identify in VBA if the current window is an item or a folder? Using Outlook 3
S Identify weekend from daily RecurrencePattern Outlook VBA and Custom Forms 2
H Better way of writing Macro? Identify multiple types of attachmen Outlook VBA and Custom Forms 5
D How to identify a mail item from a public folder in MS Outlook Outlook VBA and Custom Forms 5
S Correct way to Identify is Mail is opened in Edit Mode Outlook VBA and Custom Forms 1
S E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
M Cannot read the calendar Using Outlook 9
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
R Cannot read Chinese message after import Using Outlook 2
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
A Can't read my mails if they are on a folder... Using Outlook 0
M Unable to read HTML Using Outlook 2
J Cannot read incoming emails Using Outlook 2
P Custom field is read only Using Outlook 1
C (Read, not read) receipt "subject" problem Using Outlook 8
