Compare incoming FROM display name to contact
  • Thread starter Thread starter Ari
Ari
We send txt to cell phones from outlook, we have these cell users in our
contacts as well, (example: phonenumber@carrier.com) is named JOE, when JOE
reply's from his cell phone the FROM display name showing in outlook from the
cell phone shows numbers (example: phonenumer@carrier.com) how can I make it
show the name JOE that I have for it in my contacts? or maybe some script
can compare it to a list in a file and then re-write the info to outlook.
The Outlook mail.SenderName property is read-only in the Outlook object
model.
You would need to use a lower level API such as Redemption
(www.dimastr.com/redemption) or Extended MAPI (C++ or Delphi only) to create
an item, copy the original to it and set whatever properties you want such
as PR_SENDER_NAME (this is low level stuff) and then save the item and
delete the original.
"Ari" <Ari> wrote in message
news:A54C10DA-6F53-494D-8985-3FC69E95CF78@microsoft.com...
> JOE
> the
> it
> Thanks
would you be able to build that for us?
> model.
> > JOE
> > the
> > it
> > Thanks
Any moderately advanced Outlook programmer could build code like that, but
this isn't the place to discuss that.
news:A5DE8855-1F3D-4FA3-A079-3EF0AF6C70C0@microsoft.com...
O Any decent tool to compare .pst files? Using Outlook 2
R compare folder contents to e-mail attachement Using Outlook 1
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
L Specific Incoming Email Address Immediately Deleted Using Outlook 2
oliv- How to distinguish whether mail is incoming or outgoing? Outlook VBA and Custom Forms 2
T Search for incoming e-mails for a specified time range Using Outlook 1
G Detect Google Drive and OneDrive links in incoming mail Outlook VBA and Custom Forms 3
T Incoming Mail Changes Fonts Using Outlook 0
R VBA to manage incoming mail Outlook VBA and Custom Forms 2
I Capture incoming emails Outlook VBA and Custom Forms 1
D VBA to edit body of incoming email and forwarding it Outlook VBA and Custom Forms 11
P Use VBA to alert if new incoming email fits criteria Outlook VBA and Custom Forms 0
A Processing Incoming E-mails with Macros Using Outlook 0
D Delete selected text from incoming emails Outlook VBA and Custom Forms 25
Danny2015 how to change incoming mail conversationtopic successfully Outlook VBA and Custom Forms 6
R IMAP & Outlook 2007: incoming messages still going to old Inbox. Using Outlook 3
A Incoming mail not downloading Using Outlook 2
G Rule starting a VB macro against incoming email Outlook VBA and Custom Forms 3
D Setup expire date for incoming mail Outlook VBA and Custom Forms 2
MattC Some fonts the wrong size in incoming emails in Outlook 2007 Using Outlook 6
Emerogork How do I set up an "Incoming mail filter" Using Outlook 12
A Gibberish Titles & Attachments @ incoming Outlook 2013 emails Using Outlook 1
K Ask about a simple script about save a incoming mail as file on local PC Outlook VBA and Custom Forms 3
J How to sort incoming email that is sent to a different address to my main one? Using Outlook 1
M Incoming invites to my imap account does not sync to outlook.com Using Outlook.com accounts in Outlook 29
S The incoming task is not valid ((when users are accepting a Task) Using Outlook 5
Commodore Unified inbox or incoming messages view Using Outlook 27
P Automatic reply on incoming messages in outlook using VBA(only Specifi person) Using Outlook 14
A Alerts on incoming emails which are not responded since 1 day Using Outlook 1
J Cannot read incoming emails Using Outlook 2
G Modify Subject line of incoming mail where I am in Cc line Using Outlook 1
J Incoming emails going to wrong sub-folder Using Outlook 4
F How to change all incoming fonts to black? Using Outlook 3
