MSSMLBIZ will not start after a Windows XP Repair
  • Thread starter Thread starter tps_art
tps_art
I had to do a Windows XP repair on my PC. Now my MSSMLBIZ for BCM 2003 will
not start. When I try and start the service my error message says that I
need the administrator to start this service but my account is the
administrator. I am migrating to BCM 2007 and need to migrate my data into
the BCM 2007 database. I tried to do a repair with my BCM 2003 SP4 install
but it did not work. Can I do a reinstall and will my data be saved in the
DB or will it be written over?
Any suggestions?
I found my problem. The Windows XP repair changed the LOG ON settings for
the MSSMLBIZ service. I changed it back to local system account and the
service started.
> Any suggestions?
> service started.
Good to hear you solved this problem.
Let us know if you have other questions. :)
Leonid S. Knyshov
Try Exchange Online http://bit.ly/free-exchange-trial
TPS - I am having the exact same problem this morning. How do I find the LOG
ON settings for the database?
Tad
> service started.
> > Any suggestions?
Go to services.msc and go to properties for the Microsoft SQL (MSSMLBIZ)
service . Click on Logon and you find the option you were looking for
Regards
Rahul Thomas
MSFT
"Tad Cooper" <TadCooper> wrote in message
news:90C246A9-2B64-4609-B313-BFC3A8A829AD@microsoft.com...
> LOG
> Thanks
> Tad
> > for
> > service started.
> > > will
> > > I
> > > into
> > > install
> > > the
> >> > Any suggestions?
L HUP Office 2007, MSSMLBIZ.msi error, outlook not installed BCM (Business Contact Manager) 1
M Start Outlook 365 at unified inbox Using Outlook 2
D Unable to change AppointmentItem.Start property Outlook VBA and Custom Forms 3
R unable to filter tasks when start date is on or before today Using Outlook 4
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
Witzker HowTo start a macro with an Button in OL contact form Outlook VBA and Custom Forms 12
A End-time meeting reminder (or "negative" time relative to the meeting start time) Using Outlook 1
N Multiple instances of Outlook on Start Menu Using Outlook 2
P Automate Outlook Start - No Active Explorer Object Found Using Outlook 10
P Outlook 2016 won't Start Using Outlook 3
O Outlook 2016 crashes at start Using Outlook 14
S Calendar loops when clicking on calendar link to start it Using Outlook 1
Diane Poremsky Cannot start Microsoft Office Outlook Error Message Using Outlook 0
Thorsten show the correct calendar on start Outlook VBA and Custom Forms 5
V Cannot start Outlook. Cannot open the Outlook window. Using Outlook 8
M Cannot start MS Office Outlook Cannot open the Outlook window Using Outlook 2
R Default Start time for Private Appointment Using Outlook 4
njs27 Start date of occurrence same as PatternStartDate Outlook VBA and Custom Forms 6
E Searching a Shared Outlook Mailbox from the start menu? Using Outlook 4
S Using "start application" rule action Using Outlook 2
A BCM does not start correctly BCM (Business Contact Manager) 10
M Clipboard Manager Not showing in Outlook 2010 on Start Using Outlook 8
L Outlook 2007 does not start with Apple iCloud-Add-In activated Using Outlook 2
V How can I start a NEW PST file without loosing my contacts & other data Using Outlook 3
D How do I start completely from scratch in setting up Outlook 2013? Using Outlook 6
P Outlook 2010 fails to start after icloud update Using Outlook 3
C Monday Start Monthly Template Using Outlook 0
L Change length of appointment start time Using Outlook 2
G Cannot start Microsoft Outlook Using Outlook 1
M I cannot start Microsoft Outlook 2013 directly opening a .eml message Using Outlook 1
E Adding Start and End Time to Daily View in Calendar Printing assistant Using Outlook 1
H Outlook 2010: Cannot start!, please help me! Using Outlook 3
D Task Start and Due Dates Using Outlook 3
R Changing Start Date Without Changing Due Date in Tasks Using Outlook 1
M Outlook wont start Using Outlook 1
N How can i hsve appointments and events to not display start or finish times Using Outlook 2
W Auto changing "You" at start of sentence...very frustrating! Using Outlook 4
G How to NOT display the start time in monthly calendar view - 2007 Using Outlook 8
S Cannot start Microsoft Office Outlook. Cannot open the Outlook window. The set of folders cannot be Using Outlook 3
S __Cannot start Microsoft Office Outlook. Cannot initialize Microsoft Office shared utilities.____ Using Outlook 4
N Start my Outlook from a server Outlook VBA and Custom Forms 1
A General, how to get started? [kwrds begin start newbie] Outlook VBA and Custom Forms 3
