Outlook rule check for messages not received
  • Thread starter Thread starter Gamecat
G
Gamecat
I have an email sent to me from the same sender every day.
I want to set up an alert for when the message IS NOT received.
Any ideas?
See the Items.Restriction function. You can restrict the Items collection of
a certain folder for instance by the Subject and ReceivedDate.
Maybe you can run the code once a day when Outlook starts. For that use the
Application_Startup event.
Best regards
Michael Bauer
Am Wed, 28 Apr 2010 23:47:01 -0700 schrieb Gamecat:
> Any ideas?
Otherwise you would need an Outlook Add-In that checks your inbox from time to time.
Tom
"Michael Bauer " <mb@mvps.org> schrieb im Newsbeitrag news:5ve1s3jbu7ew$.ahyd3yo4ttpt$.dlg@40tude.net...
> > Best regards
> Michael Bauer
> Category Manager -
> SAM - The Sending Account Manager:
> > Any ideas?
R Rogue Outlook Rule ? Using Outlook 2
Liza Creating a rule in outlook to filter messages Using Outlook 0
T Create Rule For Secondary E-Mail Address In Outlook 2016 Using Outlook 4
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
I outlook rule keywords based on list Using Outlook 0
M Outlook 2016 Desktop - Automatic Rule Processing Using Outlook 3
I Create custom Outlook 2013 Rule in Office 365 Outlook VBA and Custom Forms 5
K Outlook moves sender's mail, but there is no rule Using Outlook 0
J Outlook creating unwanted rule on its own Using Outlook 1
F Outlook rule, specific words, not specific words Using Outlook 1
R Outlook 2013 VB rule to auto save attachments with different file types Outlook VBA and Custom Forms 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
Gary Brown Outlook 2013 VBA to run a rule Outlook VBA and Custom Forms 13
J Outlook Rule - Create Link in Forwarding Message Outlook VBA and Custom Forms 2
B Outlook 2000 Rule to Move txt msg Not Working if size >24KB Using Outlook 3
G Creating an Outlook Rule using Internet Header time Using Outlook 1
N rule to move sent mail to the deleted folder in outlook Using Outlook 4
M Outlook Rule To Redirect Mail - Script to overcome lack of cc's & others Using Outlook 0
J outlook rule doesn't run automatically Using Outlook 0
K Implementing an AND logic rule in OUTLOOK Using Outlook 1
C Outlook rule moves e-mail to a deleted folder Using Outlook 1
E Outlook rule only active certain times of day Using Outlook 6
W Outlook sent to "person" rule excluding cc Using Outlook 2
D Private messages not forwarding by rule? Outlook 2007 Using Outlook 1
J Create or Import a Outlook Rule through C# code. Outlook VBA and Custom Forms 2
D Create a macro in Outlook to run a rule Outlook VBA and Custom Forms 32
N How to create hidden rule in outlook 2007 Outlook VBA and Custom Forms 3
T forcing a rule when opening outlook via code Outlook VBA and Custom Forms 1
N Outlook alert/memo/rule when an email does not arrive Using Outlook 3
R Outlook 2003/2007 Rule and Conditions for InBox VBA customization Outlook VBA and Custom Forms 3
K Re: Cuestom outlook rule using vba Outlook VBA and Custom Forms 4
L new outlook contacts searching Using Outlook 2
W New Outlook PEOPLE blank Using Outlook 7
