Saving Emails as Messages Problems with Access Data Collection et
  • Thread starter Thread starter Chris
C
Chris
Ok Community,
Ken helped me get 97% of the emails saved as ".msg" format outside of
Outlook. However, due to the nautre of what I am copying, I truly need 100%
saved. One of the problems I have identified are Access Data Collections.
Some have a messageclass of IPM.InfoPath.Form.InfoPath and others are
IPM.Note. The difference are whether or not the forms were sent via the HTML
option in Access or as an InfoPath form. The source doesn't matter because
if it is in the mail folder, it must be copied.
Another problem I noted, is that even though the code tells it to, it does
not apply the Category "Not Copied" (category exists) to all items not
copied. It also doesn't apply a category that has been added as a test
immediately after instatiating the item but those items copy out as the msg
format.
Finally, I have seen many examples of how to step through the Outlook Folder
structure for a pst (not an Exchange mailbox), I need to be able to recreate
that folder structure externally and then copy the emails inside that folder
as well. I am assuming that the email copies would occur immediately after I
have created the folder using existing code (nested loops). The nice thing
is that due to space limitations at our location, the save location will have
to be the Desktop on the C drive (C:\Users\<username>\Desktop\MailBurn\" and
not on a network location. I will need to recreate the entire folder structure
I am including the existing text to help solve the first two issues. Thanks
to one and all for your time and assistance with these problems.
Chris
-----CODE START---
Public Sub ExportSAR()
Dim TheEmail As Object
Dim ReportEmail As ReportItem
Dim eItem As Outlook.Items
Dim EmailNS As NameSpace
Dim fldrCount, EmailPath2, NbrItem, myfolder
Dim strSubj, strTime, strSend, mailClassCheck, EmailPath As String
Dim NewFileName, ReportHeader As String
Dim Cats
Dim CheckErr, Exists As Boolean
CheckErr = False
Set EmailNS = Application.GetNamespace("MAPI")
Set myfolder = Application.ActiveExplorer.CurrentFolder
NbrItem = myfolder.Items.Count
On Error GoTo Error_Handler
EmailPath = BrowseForFolderShell
MsgBox EmailPath
'EmailPath = InputBox("Enter the save folder location:", "Email Save
Path", CurDir)
For i = 1 To NbrItem
Set TheEmail = Application.ActiveExplorer.CurrentFolder.Items.Item(i)
TheEmail.Categories = TheEmail.Categories & ";" & "Red Category"
mailClassCheck = TheEmail.MessageClass
If Left(mailClassCheck, 6) = "REPORT" Or Left(mailClassCheck, 6) =
"Report" Or Right(mailClassCheck, 8) = "InfoPath" Then
Set ReportEmail =
If ReportEmail.Subject = "" Then strSubj = "no subject"
If Right(ReportEmail.MessageClass, 2) = "DR" Then ReportHeader =
"DeliveryReport" Else ReportHeader = "Read Receipt"
strSubj = Replace(ReportEmail.Subject, "/", "-")
strSubj = Replace(strSubj, "\", "-")
strSubj = Replace(strSubj, ":", "--")
strSubj = Replace(strSubj, "?", sReplace)
strSubj = Replace(strSubj, "*", sReplace)
strSubj = Replace(strSubj, Chr(34), sReplace)
strSubj = Replace(strSubj, "<", sReplace)
strSubj = Replace(strSubj, ">", sReplace)
strSubj = Replace(strSubj, "|", sReplace)
strTime = Replace(ReportEmail.CreationTime, "/", "-")
strTime = Replace(strTime, "\", "-")
strTime = Replace(strTime, ":", ".")
strTime = Replace(strTime, "?", sReplace)
strTime = Replace(strTime, "*", sReplace)
strTime = Replace(strTime, Chr(34), sReplace)
strTime = Replace(strTime, "<", sReplace)
strTime = Replace(strTime, ">", sReplace)
strTime = Replace(strTime, "|", sReplace)
NewFileName = ReportHeader & "_" & strSubj & strTime & ".msg"
If NewFileName <> "" Then
ReportEmail.SaveAs EmailPath & NewFileName, olMSG
MsgBox "No file name was entered. Operation aborted.", 64,
"Cancel Operation"
GoTo Step1
If TheEmail.Subject = "" Then strSubj = "no subject"
strSend = Replace(TheEmail.SenderName, "/", "-")
strSend = Replace(strSend, "\", "-")
strSend = Replace(strSend, ":", "--")
strSend = Replace(strSend, "?", sReplace)
strSend = Replace(strSend, "*", sReplace)
strSend = Replace(strSend, Chr(34), sReplace)
strSend = Replace(strSend, "<", sReplace)
strSend = Replace(strSend, ">", sReplace)
strSend = Replace(strSend, "|", sReplace)
strSubj = Replace(TheEmail.Subject, "/", "-")
strTime = Replace(TheEmail.ReceivedTime, "/", "-")
NewFileName = strSend & "_" & strTime & "_" & strSubj & ".msg"
TheEmail.SaveAs EmailPath & NewFileName, olMSG
"Cancel Operation"
Step1:
strSubj = ""
strTime = ""
Next i
GoTo Done
Error_Handler:
If TheEmail Is Nothing Then
MsgBox Err.Number & ":" & Err.Description
MsgBox TheEmail.MessageClass & Chr$(13) & TheEmail.Subject & Chr$(13) &
Err.Number & ": " & Err.Description
TheEmail.Categories = TheEmail.Categories & ";" & "Not Copied"
TheEmail.Save
Resume Next
Done:
Public Function BrowseForFolderShell(Optional Hwnd As Long = 0, Optional
sTitle As String = "Browse for Folder", Optional BIF_Options As Integer,
Optional vRootFolder As Variant) As String
Dim objShell As Object
Dim objFolder As Variant
Dim strFolderFullPath As String
Set objShell = CreateObject("Shell.Application")
Set objFolder = objShell.BrowseForFolder(Hwnd, sTitle, BIF_Options,
vRootFolder)
If (Not objFolder Is Nothing) Then
'// NB: If SpecFolder= 0 = Desktop then ....
If IsError(objFolder.Items.Item.Path) Then strFolderFullPath =
CStr(objFolder): GoTo GotIt
On Error GoTo 0
'// Is it the Root Dir?...if so change
If Len(objFolder.Items.Item.Path) > 3 Then
strFolderFullPath = objFolder.Items.Item.Path '&
Application.PathSeparator
strFolderFullPath = objFolder.Items.Item.Path '& Application.
'// User cancelled
GoTo XitProperly
GotIt:
BrowseForFolderShell = strFolderFullPath & "\"
XitProperly:
Set objFolder = Nothing
Set objShell = Nothing
End Function
-----CODE END-----
OK, I discovered the problem with the access data collections. The files
name ends up being too large so I put a check in to check the length of the
file name and if it is too long, ask the user to rename it with the original
filename being the default.
The Code is:
If Len(NewFileName) > 145 Then
TooLong:
NewFileName = InputBox("Please Enter a New File Name that is
shorter than 146 characters." & Chr$(13) & "Current file name is " &
Len(NewFileName) & "characters.", _
"File Name Too Long", NewFileName)
MsgBox "File name is still too long." & Chr$(13) & "Current file
name is " & Len(NewFileName) & "characters.", vbOKOnly, "File Name is Too
Long"
GoTo TooLong
"Chris" wrote:
> Ok Community,
> format.
> Chris
> -----CODE START---> Public Sub ExportSAR()
> Dim Cats
> CheckErr = False
> MsgBox EmailPath
> Path", CurDir)
> Set ReportEmail =
> Else
> "Cancel Operation"
> Exit Sub
> End If
> GoTo Step1
> End If
> Else
> "Cancel Operation"
> Exit Sub
> End If
> Step1:
> strSubj = ""
> strTime = ""
> Next i
> GoTo Done
> Error_Handler:
> Else
> TheEmail.Save
> End If
> Resume Next
> Done:
> End Sub
> vRootFolder)
> On Error Resume Next
> On Error GoTo 0
> Else
> End If
> Else
> '// User cancelled
> GoTo XitProperly
> End If
> GotIt:
> XitProperly:
> End Function
> -----CODE END-----
M Dialog called up multiple times when saving emails from macro Outlook VBA and Custom Forms 2
Kevin H Remotely saving emails Using Outlook 1
D Saving outlook emails in html and attachments Using Outlook 4
S Automate saving of attachments on new incoming emails Outlook VBA and Custom Forms 3
Rupert Dragwater Background colors not saving in Outlook 365 Using Outlook 15
CWM330 Saving Data: Don't check certain folders Using Outlook 2
D Outlook 2016 Outlook not saving Sent Items Using Outlook 4
B Saving items under a folder Using Outlook 3
V Saving attachment from outlook in My Documents Outlook VBA and Custom Forms 14
T Saving all email to file folder in Windows Using Outlook 2
C Saving Outlook attachments and links to attachments with VBA Outlook VBA and Custom Forms 2
R Outlook 2010 Modify Style "Do not check spelling or grammar" not saving Outlook VBA and Custom Forms 0
R Outlook Office 365 not saving addresses Using Outlook 0
P Saving All Messages to the Hard Drive Using VBA Outlook VBA and Custom Forms 5
S Editing an email with notes and saving it for record using Macro Outlook VBA and Custom Forms 3
J Outlook 2013 crashes saving VBA & clicking tools | digital signature Outlook VBA and Custom Forms 1
bifjamod Saving sent email to specific folder based on category with wildcard Outlook VBA and Custom Forms 1
N Saving .msg as sent item on send Outlook VBA and Custom Forms 1
erichamion Changes to meeting body not properly saving Outlook VBA and Custom Forms 4
A ItemAdd on Imap Folder get endless loop after saving item Using Outlook 5
T From Field Blank when saving to folder other than Sent items Using Outlook 2
L Outlook DST (Daylight Saving Time) problem Using Outlook 0
F Using Outlook 2007 as an IMAP Mail Station Without Saving Data Locally Using Outlook 2
E Saving Changes To Edited E-Mail Received Message Using Outlook 0
D File Lock issue when saving message from Outlook to new folder Using Outlook 1
D Remove extension while saving attachments Using Outlook 1
K Printing & Saving Outlook Contacts Using Outlook 3
S Not saving attachments in the Sent Folder Using Outlook 2
W Default Saving a message as text Using Outlook 2
R Outlook 2007 QAT buttons not saving Using Outlook 2
C Exchange 2003 - Outlook 2003 - Calendar entries saving over each other Using Outlook 2
J Saving Published Outlook Form as msg Using Outlook 1
