Read receipts and preview panes
I am using Outlook 2003 and have it configured to never send read receipts at any time and the preview pane is configured to not mark anything as 'read', period. However, an acquaintance of mine says they get a read receipt from me when I view an e-mail from them using the preview pane. Is this possible? I know they have a Microsoft OS and their e-mail client is Outlook but I have no idea as to what OS and Outlook version they're using.
If the message is not marked as Read, then no, they shouldn't be getting a receipt. Is it a read or delivery receipt? delivery receipts are sent by the server and you have no control over it.
also, set outlook to ask, then you'll know if its sending them when you read.
B Delete Read Receipts in Your Outlook Outlook VBA and Custom Forms 0
R Filtering messages requesting Read Receipts Using Outlook 1
T read receipts while processing emails Outlook VBA and Custom Forms 5
Rupert Dragwater Mail won't show as read Using Outlook 2
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
D Can't read some emails - text size too small. Using Outlook 2
S E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
M Cannot read the calendar Using Outlook 9
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
R Cannot read Chinese message after import Using Outlook 2
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
A Can't read my mails if they are on a folder... Using Outlook 0
M Unable to read HTML Using Outlook 2
J Cannot read incoming emails Using Outlook 2
P Custom field is read only Using Outlook 1
C (Read, not read) receipt "subject" problem Using Outlook 8
S iCloud Outlook Calendar is read only Using Outlook 1
Z Mark moved copies as "Read" Using Outlook 19
