Rule for dispatching messages
robimaxi2002
Dear all,
I'm seeking your advice because I have the following problem:
we have a functional mailbox where customer can send their requests.
I would like to a system to assign each e-mail as it arrives to one of a list of 15 officers.
I could not do it with RULES, is there any work-around?
Many thanks in advance for your help,
Roberta
CWM330 This rule has a condition that the server cannot process? Using Outlook 1
A rule name into message - how? Outlook VBA and Custom Forms 5
A manual rule sends mail to wrong folder Using Outlook 5
bhamberg Finding a rouge rule... Using Outlook 6
D How to get this rule to work Using Outlook 0
R Rogue Outlook Rule ? Using Outlook 2
L Making rule to move email to folder from one O365 domain Using Outlook 1
