large mailbox question using 2010 on exchange 2k3
davehedgehog
Exchange 2003. User is using outlook 2010.
I have an issue relating to a shared mailbox. When the user (this actually happens to more than one user) tries to move mails or view subfolders in the mailbox they get the error "Cannot display the folder. Microsoft Outlook cannot access the specified folder location. Your server administrator has limited the number of items you can open simultaneously. Try closing messages you have opened or removing attachments and images from unsent messages you are composing"
This does not happen on outlook 2k3.
After a quick Google I have seen something mentioned about the way that outlook 2010 behaves with large mailboxes, and that this errors related to the amount of open connections. If this is true is there more detailed info anyway anyone can point me towards?
I'm trying to find out exactly what this problem is and what the difference between outlook 2k3 and 2010, whether the above is correct and if so more information on it. I've googled but had no luck. Ultimately a fix for this is neede if possible as currently on Windows 7 this mailbox is unusable.
Many thanks for any input, much appreciated.
I have seen similar issues with large mailboxes and Outlook 2010 (32bit) running on Win7 (64bit) against a 2003 Exchange server.
The fix for me was to turn off Cached Exchange Mode. It looked like everything was going to crash when reopening Outlook, but all was better. This resolved 2 different issues with 2 different users on the same Exchange server.
Hope this helps,
FatToad
I don't think this is related to the 500 folder limit... because i think was also in outlook 2003, but the error message looks familar. (will check on it.)
The difference may be that cached mode in outlook 2010 caches all shared folders too (by default). Rather than turning off cached mode completely, you can disable it for shared accounts.
Account settings, double click on the account, more settings, second tab in the dialog.
T Create a group from a large To distribution list Using Outlook 3
U Trouble sending large files to a email group but can to the individuals in that group Using Outlook 8
J How to Fix “Encounter a large number of conflict items in Exchange OST file” Using Outlook 2
Diane Poremsky Repair a Large Outlook Personal Folders File (over 2GB) Using Outlook 0
M Large emails not sent from correct account Using Outlook 0
V Your Imap server wants to alert you to the following: Message too large Using Outlook 4
V IMAP: email is too large Using Outlook 1
M PST large - Imap gmail business Using Outlook 0
J Contact page too large for screen. Can't see categories, etc. Using Outlook 1
K Outlook 2010 creating extremely large PST files for IMAP accounts Using Outlook 3
I How to send just a few emails at a time to a large group in Outlook 2010 Using Outlook 3
A OL 2007 problem - sudden large increase in message size Using Outlook 12
K How to split large email when sending Using Outlook 1
D Font size too large on received emails in outlook 2010 Using Outlook 26
C RE: unable to delete large message clogging outbox Using Outlook 3
V Move old emails or emails with large attachments ? Outlook VBA and Custom Forms 1
J How do I cancel an email with large attachment? Using Outlook 4
K Designing a form for distribution, with link to (large) data sourc Outlook VBA and Custom Forms 5
kburrows "New" Outlook Desktop App Mailbox Size Using Outlook 4
S Email Macros to go to a SHARED Outlook mailbox Draft folder...NOT my personal Outlook Draft folder Using Outlook 2
C Outlook 365 Multiple different Signatures on Shared Mailbox Using Outlook 0
S Outlook 365 Shared mailbox contact group member numbers not matching Using Outlook 0
C Your mailbox has been temporarily moved ... Using Outlook 2
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
A New email notification on shared mailbox Outlook VBA and Custom Forms 0
N Shared mailbox in cached mode Using Outlook 0
F How to show assigned tasks under certain mailbox? Using Outlook 4
S Import contacts to a shared mailbox Outlook VBA and Custom Forms 2
D Delete Emails from Senders in Shared Mailbox Outlook VBA and Custom Forms 1
O Office 365 - Outlook - Password protect your mailbox Using Outlook 7
C Changed By field not displaying individual user's name in O365 Shared Mailbox Using Outlook 9
M other user's mailbox won't open, forms disappeared Using Outlook 42
