mark as read per folder options
helpmeplease
im wondering if either of these two options can be brought about:
create rule to mark a message to mark as read after x hours
on a folder by folder basis set custom rules for how long to wait before marking all messages as read.
thanks.
No, sorry, you can't do that using rules. You'll need an addin such as Auto-Mate that can run later. It's also possible to do it using Run Rules Now command - but it will be based on the dates, not hours.
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
Z Mark moved copies as "Read" Using Outlook 19
Z "Mark All as Read" in Outlook 2007 extremely slow Using Outlook 1
A Mark all as read for public folders Using Outlook 14
N Changing the 'Mark item as read when selection changes' at runtime Outlook VBA and Custom Forms 1
B Move Sent Email to archival pst folder and mark as read - HOW TO Outlook VBA and Custom Forms 2
B Mark copy of sent email as read - VBA? Outlook VBA and Custom Forms 3
J Mark as read Outlook VBA and Custom Forms 2
M Mark as read Outlook VBA and Custom Forms 5
T Setting a delegate to not mark items as read Using Outlook 9
K mark emails with colour manually (like in thunderbird) Using Outlook 1
O Office 365 Outlook - mark to download Using Outlook 0
S Codes for "Mark Complete" the task Outlook VBA and Custom Forms 2
S Mark as Unread unless Categorized by Color Using Outlook 0
T Adding "Mark As Complete" btton to Task Remindet Pop-Up Using Outlook 3
F Automatically close email after selecting mark unread Using Outlook 1
T outlook 2013 does not mark multiple forward messages as forward Using Outlook 2
7 Macro to mark message as junk and delete Outlook VBA and Custom Forms 3
V Mark BCC when emails is sent from specific account Outlook VBA and Custom Forms 2
B Outlook 2010: how to mark messages without opening? Eg for deletion Using Outlook 2
N Mark or follow up emails in shared mailbox Using Outlook 2
I Pound Symbol in emails show as � (black diamond with white question mark inside) - Office 2010. Using Outlook 11
J Pasting into Outlook 2003 produces blue question mark Using Outlook 2
R Macro to mark item unread Outlook VBA and Custom Forms 2
Rupert Dragwater Mail won't show as read Using Outlook 2
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
D Can't read some emails - text size too small. Using Outlook 2
B Delete Read Receipts in Your Outlook Outlook VBA and Custom Forms 0
S E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
M Cannot read the calendar Using Outlook 9
L Email Read and Delete Outlook VBA and Custom Forms 4
