Setting a delegate to not mark items as read
TVBhcmFkaXM
Our office has a user with an assistant set as a delegate in Outlook
(Exchange environment). Currently, if the assistant views an email in the
user's Mailbox, it is set to "Read" status, which can lead to confusion as to
which items have or have not been read by the user themself. Is there a
setting (both users have Outlook 2007 installed) that will stop items viewed
by the assistant from being set to "Read" status?
Roady [MVP]
Disable the option to automatically mark items as read.
Tools-> Options->tab Other-> button Reading Pane
TVBhcmFkaXM
Thanks, but won't this apply to the assistant's mailbox as well? Is there a
way to disable it only for the shared mailbox?
Roady [MVP]
Yes, it applies to all mailboxes and no, you cannot set this option on a
per-mailbox level.
Personally, I always disable the option to automatically mark messages as
read and use CTRL+ENTER to mark them as read manually.
Another way to go would be that the assistant marks the messages that should
remain unread back to unread. As he/she is the assistant, shouldn't he/she
pre-process the manager's mail? Then the assistant can flag the items which
still needs attention of the manager and the manager can mark it as complete
when finished. There are other working scenarios as well of course.
K
Kimberly
Can I have found the one thing that Outlook does better than Lotus notes???
I sure hope not.
Microsoft really need to come up with a solution for this. I need to read
things and have them marked read for me and left marked unread for my boss.
This is essential! Yes I know remarking them is an option, but with the
number of emails I read each day that is a PITA.
covolume
We have exactly the same problem... and no answer in the forums.
I have 10 people reading the same mailbox, and everyone has to see every mail "unread" until he himself reads it.
Did you find a solution to that ?
Forum Admin
Unfortunately, when you use a shared mailbox, the mailbox status isn't per user, like it can be if you use public folders. There really isn't a good solution - public folders may not be available. One option is to use a DL instead of a shared mailbox, but how well that will work really depends on how you use the mailbox.
covolume
It's strange that MS didn't think of such a solution. I'm sure we aren't the only people needing that, and Lotus Notes has offered this decades ago.
Anyway : what do you mean by DL ? Download a copy of the mailbox, is that it ?
DL = distribution list. This method would send a copy of the message to every user. This works well for notification-type messages but not so good for Sales or Support aliases where one person is supposed to reply, as you can't see if the message is marked as being replied to (because you have your own copy of the message).
Microsoft has supported it for decades too - but in Public folders, not mailboxes.
AlphonseG Outlook 365 Outlook Crashes on setting SaveSentMessageFolder Outlook VBA and Custom Forms 5
Marc2019 Setting up an Outlook Account on Mac Os 10.6.8 Outlook 2011 Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
B Setting rules Using Outlook 1
B Setting defaults Using Outlook 2
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
Ed Sheehan Unusual behaviour in setting Sender (Outlook 2016) Outlook VBA and Custom Forms 4
Jennifer Murphy Equations don't comply with style setting to left justify Using Outlook 0
J Setting default address book Using Outlook 0
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
Diane Poremsky Setting up an Outlook.com IMAP account Using Outlook 0
Diane Poremsky Setting the default Country for Outlook Contacts Using Outlook 0
Diane Poremsky Adjusting Outlook's Zoom setting in Email Using Outlook 0
O Setting default format for composing/replying to emails Using Outlook 3
B Outlook Calendar/setting appointments Using Outlook 1
Diane Poremsky Setting Custom Reminder Times Using Outlook 0
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
A Setting RULES with more than one condition in MS OUTLOOK Using Outlook 6
L Setting up my PA's Outlook Using Outlook 7
N "Instant Search" setting a default view Using Outlook 3
H SETTING UP A "NEW" NEVER HAD NEVER USED EMAIL ACCOUNT Using Outlook 9
K Setting Default Email Address for Meeting Replies Using Outlook 3
S Setting up Outlook 2010 to work with custom domain outlook.com account BCM (Business Contact Manager) 3
D Setting defult "Show a room list" Using Outlook 0
Horsepower Setting appointments in calendar Using Outlook 3
J Setting tabs in contacts / notes field Using Outlook 0
T Setting a Default Subject from a certain Signature Using Outlook 0
K Help Needed - setting up Email in Outlook 2013 Using Outlook 3
mikecox setting Default area code in Contacts Using Outlook 5
G Outlook2013 - "From" name doesn't change even when changed in Account Setting Using Outlook 4
D How do I start completely from scratch in setting up Outlook 2013? Using Outlook 6
V View zoom setting changing Using Outlook 1
C Setting up Outlook 10 on Widows 8 using Google Server Using Outlook 3
I Outlook Appointments - Setting default text in message body Using Outlook 3
T Setting Color codes for each user of a shared Calendar Using Outlook 1
J setting date in drafts Using Outlook 4
