reply using secondary mailbox
code_dude
I have a user who has a primary email account(primary@domain.com) and a secondary account(secondary@domain.com) configured in his Outlook 2010. The way it was defined in Exchange 2010 is like this:
1. All emails sent to secondary@domain.com is forwarded to primary@domain.com
- no copies left in mailbox
2. Primary@domain.com can send as secondary@domain.com
Everything works fine but the user is now asking that if someone sent an email to secondary@domain.com, replying to the sender automatically populates the secondary@domain.com in the TO field instead of the primary@domain.com.
When an email is sent to primary@domain.com, primary@domain.com should still be the one populated in the TO field.
is this possible?
larry
No, its not possible unless you use an addin. Mask or the two from ivasoft can do this. D has links to these products in the tools section at Sending Email from a Secondary Exchange Mailbox
I seem to recall she has a macro too but i can't find it, but that is another option.
The macros I have - Reply using the address a message was sent to is one - won't do it, but it should be fairly easy to tweak that macro. The other option is a reply macro assigned to a toolbar button - when the user wants to reply using acct 2, he hits reply button 2.
H send reminder if no reply received on first or original email using macro Using Outlook 2
wallisellener Unable to reply/post/create new thread using Chrome BCM (Business Contact Manager) 5
reza Macro to automatic reply using orignal mail Outlook VBA and Custom Forms 10
B Auto reply using macro include original email Using Outlook 4
G Reply using address a message was sent to Using Outlook 2
M Reply Macro using O365 Connected Account Using Outlook 2
A Reply/Forward Emails using Mail Merge BCM (Business Contact Manager) 0
P Automatic reply on incoming messages in outlook using VBA(only Specifi person) Using Outlook 14
L reply to message using a custom template Using Outlook 1
R OL2010; How to ALWAYS Reply/Forward using HTML? Using Outlook 1
P Automatic Greeting "Hello Name," when Reply All is clicked Outlook VBA and Custom Forms 1
W Reply to email Using Outlook 4
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
ThinkToday Calculate reply time of outlook mail Using Outlook 1
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
E reply Using Outlook 0
evdbogaard Reply with only last message cited Using Outlook 1
Rupert Dragwater Deleted email address keeps showing up in reply Using Outlook 12
M Reply Inline With a Outlook Template Outlook VBA and Custom Forms 6
J VBA Run When Reply Outlook VBA and Custom Forms 4
D Font in Reply is much larger than normal, how to reset ...? Using Outlook 4
