Cc and Bcc not working
jimji
The Cc and Bcc functions are not working in my Outlook 2007 (using Windows XP) I've searched the net fairly extensively and can't find any help with this problem. Hopefully you can help me!
thanks,
Jim Migdoll
CC's usually aren't a problem, but some spam filters will filter BCC's. How many names are on the CC'd messages?
What antivirus do you use? Is it scanning outgoing mail? Do the messages arrive if you run outlook in Safe mode?
I've been testing with just one name in the CC and one in the BCC. I use Avast free version. I don't think it scans outgoing. I haven't tried running in Safe mode. Actually I wouldn't know how!
Further testing of my cc and bcc functions reveals that it does work! ... Just not when I use it to my wife's computer, which is about 6 feet away from me?! Very strange. Any ideas?
cheers,
Jim
it's not the distance - but something is filtering your mail as spam. It could be the mail server, it could be her antispam filters. Did you check her junk folder? If everyone else gets it, its not your AV filtering it.
Try this: address a message to her and delete her name from autocomplete when it comes up. Does it work when you retype it?
cheers,
Jim
Thanks for your help till now Diane. I'm afraid that I've wasted your time! I was sure that neither the cc nor the bcc functions worked when I tested sending them to my wifes computer. Alas .. it appears they do work. Anyway thanks for being there for any future Outlook queries.
all the best,
Jim
M CC AND BCC Using Outlook 1
S BCC lists addressees Using Outlook 2
T bcc and Google imap Using Outlook 3
V Mark BCC when emails is sent from specific account Outlook VBA and Custom Forms 2
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
V using Bcc in Outlook.com 2013 Using Outlook 1
K received bcc as encrypted Using Outlook 12
V Contact group: addresses in BCC? Using Outlook 2
C a BCC script question Using Outlook 1
C BCC - How many email address will it accomodate? Using Outlook 2
P help me plase !!! outlook 2007 I can see mail Bcc Using Outlook 1
N How do you BCC Someone Using Outlook 1
S Automatically move recipients to BCC field Using Outlook 3
M Automatic Bcc Using Outlook 2
L automating a BCC on every email Using Outlook 1
williamlambton Customised To, CC, BCC and Have-replies-sent-to columns in message lists. Using Outlook 16
A How to disable bcc option in GAL - Address Book - Exchange 2007 Exchange Server Administration 4
D BCC based upon TO address Outlook VBA and Custom Forms 1
G All contacts from Contact Folder to BCC by code Outlook VBA and Custom Forms 1
G Populate BCC field with all Contacts within a Contact Folder Outlook VBA and Custom Forms 4
S BCC How to? Outlook VBA and Custom Forms 1
R (Outlook2003)Monitor change for "to" "cc" "bcc" on message compose dialog? Outlook VBA and Custom Forms 6
R suppress BCC Outlook VBA and Custom Forms 1
R how to display Bcc if not available? Outlook VBA and Custom Forms 1
P To: or CC: or BCC: Outlook VBA and Custom Forms 4
Y bcc macro Outlook VBA and Custom Forms 1
P Outlook 2016 Working Offline Using Outlook 2
T SMTP suddenly quit working - password Reset Using Outlook.com accounts in Outlook 3
A Outlook 365 Outlook (part of 365) now working offline - argh Using Outlook 5
