WithEvents not working
foncesa
Outlook 2013 32 bit
If someone could figure out what's wrong with the below WithEvents that it does not fire with new email.
   Dim appOl As Outlook.Application
   Dim ns As Outlook.NameSpace
   Set appOl = Outlook.Application
   Set ns = appOl.GetNamespace("MAPI")
   Set Items = ns.GetDefaultFolder(olFolderInbox).Folders("Personal Mail").Items
Private Sub Items_ItemAdd(ByVal item As Object)
On Error GoTo GetAttachments_err
   Dim appOl As New Outlook.Application
   Dim Inbox As Outlook.MAPIFolder
   Dim myDestFolder As Outlook.MAPIFolder
   Dim item As Object
   Dim Atmt As Outlook.Attachment
   Dim FileName As String
   Dim i As Integer
   Dim iLoop As Integer
   Dim Items As Outlook.Items
   Dim moveEmail As Boolean
   Set Inbox = ns.GetDefaultFolder(olFolderInbox)
   Set item = Inbox.Items
   Set myDestFolder = Inbox.Folders("Personal Mail")
Is macro security set to low?
Did you click in Application_start up and click the Run button?
Is the mail being moved to this folder - the code only works on mail as its dropped into the folder. Test it by removing folders("personal mail") from the code and see if it works.
Thanks for response.
Is macro security set to low? Outlook 2013 Enable all Macros (option selected)
Did you click in Application_start up and click the Run button? Yes it runs properly from Private Sub Application_Startup()..... End Sub
But it does not call the Private Sub Items_ItemAdd(ByVal item As Object) the script which will get the attachments, thats where something is wrong?
Set Items = ns.GetDefaultFolder(olFolderInbox).Folders("Personal Mail").Items Tried with this option also.
I feel the WithEvents is wroking perfectly the only part the script is not called automatically.
Please suggest, help.
R Class Modules and WithEvents Outlook VBA and Custom Forms 2
M Create email from Access on Outlook and make sure that email has beensent using WithEvents method Outlook VBA and Custom Forms 3
P Outlook 2016 Working Offline Using Outlook 2
T SMTP suddenly quit working - password Reset Using Outlook.com accounts in Outlook 3
A Outlook 365 Outlook (part of 365) now working offline - argh Using Outlook 5
R Outlook Working off line Using Outlook 0
H How to Fix 1510-370-1986 Garmin GPS Not Working Outlook VBA and Custom Forms 0
Commodore Automatic switch between working offline/online Using Outlook 4
F Searches are not working properly Using Outlook 1
Jennifer Murphy Spam filter not working Using Outlook 13
A calendar invites sent from Microsoft Outlook to Mac Outlook is not working Using Outlook 2
F KB4475563 stops VBS at forms working Outlook VBA and Custom Forms 3
D Archive by receive date not working Using Outlook 2
cricket1001 Shade non-working days in calendar Using Outlook 0
A rules not working Using Outlook 2
V Autocomplete not working on new email account Using Outlook 4
