Weird naming of fields in Contacts
Joepiet
Outlook 2013 32 bit
Since one or two months there is something wrong with the naming of some fields in the contacts, accounts and potential customers windows.
Under 'Internet' the first field should be 'E-mail'; now it is 'E-mail2'. Under 'Telephone numbers' the first field is 'Home', it should be 'Work'. There are possible other fields corrupted which I don't know of, because I don't use them.
In the list-view of contacts etc those fields are named correctly, oddly enough: E-mail2 is E-mail and with telephone numbers 'Home' is Work. Anyone familiar with this problem aand how to solve it?
My BCM is in Dutch so there can be translations slightly wrong. Excuses.
Aholder
Outlook 2013 32 bit
Today installed SP1 for office 2013 - the bug still there.
Is MS f kidding us?
Aholder
Outlook 2013 32 bit
P.S.:
Has anyone tried to install SP1 on CLEAN office (without buggy updates)? Result for our case?
I had a clean install of a beta build and it was in it. I assume it's going to be a problem in a newer clean install too.
Aholder
Outlook 2013 32 bit
Thanks for reply, Diane.
Have you ever tried export/import function of BCM?
I'm trying to downgrade office from 2013 to 2010 and respectively transfer BCM database, but it cannot be done directly due to incompatibility.
I tried to export whole 2013 database in *.bcm file and then import it in Outlook 2010. Formally import works, but connection between emails and history records is lost (i.e. clicking on history record opens only plain text history record of email, not original email itself, even if PST file with this email connected as default to Outlook 2010)
Forum Admin
I haven't used it to downgrade, but the behavior is typical - links are broken when you use import/export. The items as linked by entryid and exporting copies the items, creating new entryid's. There may be other factors involved with BCM exports, i haven't looked at the export file, but if it's not the entryid, then it's some other id that is changed in the import/export and that prevents outlook from linking the two properly. (With a SQL db, it could the index key)
Aholder
Outlook 2013 32 bit
uhmm... pity
May be some rude transfer of SQL database could help?
Or "unofficial" SQL tool aimed at BCM?
I tried direct copying of MDF/LDF files, but it doesn't work either.
Bardiferous Weird Contacts Behavior - Can't find any in any address book, but they're in there Using Outlook 3
C New weird behavior (or, why can't they leave well enough alone?) Using Outlook 0
R The return of weird graphical glitches in Outlook? Using Outlook 2
K After Carbonite restore pst files are found in a weird location Using Outlook 2
J Weird contacts disappearance Using Outlook 1
wallisellener BCM - Weird behaviour BCM (Business Contact Manager) 20
J Disabling "Myxxx" naming Using Outlook 3
J Account, profile, and PST naming in Outlook 2010 IMAP Using Outlook 2
C View doesn't refresh (fields or formatting) Using Outlook 1
M Accessing ALL Outlook contact fields Outlook VBA and Custom Forms 3
F Appointment Show All Fields Using Outlook 1
F MAPI, User Defined Fields and perspective after 20 years Outlook VBA and Custom Forms 0
cimbian street address fields contain 0A0D Outlook VBA and Custom Forms 2
P Outlook custom fields "events" Using Outlook 0
J Add Fillable Fields to Existing Template Outlook VBA and Custom Forms 1
G Addition of 2 fields based on checkboc true or false Outlook VBA and Custom Forms 2
M Multiple User Defined Fields that can be added, changed, updated using VBA and user form Outlook VBA and Custom Forms 0
S VBA with User Defined fields Outlook VBA and Custom Forms 9
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge Using Outlook 0
O VBA to extract email (fields and body) to Excel Outlook VBA and Custom Forms 14
H How to export *all* fields from Outlook Using Outlook 2
L Change the displayed fields in calendar view Using Outlook 1
N Export Outlook custom forms fields to excel Outlook VBA and Custom Forms 1
M Recurrence and custom fields Outlook VBA and Custom Forms 0
Diane Poremsky Hiding Global Address Book Fields Using Outlook 0
M Map Outlook user defined fields onto a Sharepoint list ??? Outlook VBA and Custom Forms 1
L Copy email body fields to excel Using Outlook 0
Diane Poremsky Add attachments and set email fields during a mail merge to email Using Outlook 0
H User designed fields not usable in contact folder views Using Outlook 0
L Outlook 2007 Search All Fields in Contacts Using Outlook 1
N How to retrieve user defined fields values to bcm form. Using Outlook 2
N How to disable user defined fields in BCM forms Using Outlook 2
M Adding fields to Task in Outlook Home and Business 2010 Outlook VBA and Custom Forms 7
W Meeting printing background fields Using Outlook 0
N Outlook 2013 vs Outlook.com Email Address fields Using Outlook.com accounts in Outlook 1
