Auto send-receive in Outlook not working
AKMathPub
After years of fluid operation, my auto send-receive function in Outlook 2007 has stopped working. I use Windows 7 Professional. I am not using Microsoft Exchange Server.
I have all of the correct options selected under "Tools > Options > Mail Setup". This malfunction started a few weeks ago, and I cannot attribute it to any known upgrade or systems software change. I am current with my Windows Updates.
Any advice?
Three different email providers feed into my OutLook account, including gmail and Comcast. Manually clicking Send-Recieve works fine. So, I can certainly do that whenever I need to. I simply find it annoying that my inbox is not updating while I multi-task.
I had it set to every 10 minutes. Just now, I reset it to 15 minutes to see whether that has a positive effect. BUT . . . another symptom of the recent failure is that the program no longer accomplishes an Auto Send-Receive upon startup, even though that preference is set.
10 minutes should be fine.
Try this: find and delete or rename the SRS file for your profile. Type or paste %appdata%\microsoft\outlook in the address bar of windows explorer and press Enter to open the folder where the SRS file is. This the send and receive settings file.
D Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/receive Using Outlook 4
T Outlook 2010 manually actioning of send and receive? remove auto actioning Using Outlook 4
B Auto scan/send Outlook VBA and Custom Forms 5
Z Re: Auto Print email and word attachments on send Outlook VBA and Custom Forms 1
Hornblower409 Hyperlinks - Disable Auto Complete Using Outlook 0
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
D Auto Remove [EXTERNAL] from Subject + ConversationTopic (WITHOUT Redemption plug-in) Outlook VBA and Custom Forms 5
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 3
C New pc, new outlook, is it possible to import auto-complete emailaddress Using Outlook 5
F Auto changing email subject line in bulk Using Outlook 2
