VBA code for Outlook
Kelli
I am looking for help. I only know a smidge about VBA code (basically what I have read here). What I am looking for is a way to remove a preceding "space" before the email address in my Outlook contacts. I have done a lot of work categorizing the email listing into specific groups and am trying not to have to start from scratch by importing the entire list again from excel (fixing in excel and importing again). Does anyone know the code that I would enter into the VBA project screen? thank you for any help you can provide.
I have a bulk contact macro st slipstick.com - you'd need to use something like trim(objContact.email1address) - if that doesn't work, then you might need to write it to the user1 field then back to the address field.
Code is here - http://www.slipstick.com/outlook/contacts/bulk-change-outlook-contacts-file-as-format/
Try this in the With block - if you need to fix email2 and email3, repeat the if/end if block, for email2address and email3address
With objContact
If objContact.Email1Address <> "" Then
      objContact.Email1Address = trim(ocontact.email1address)
   .Save
Z Default VBA code for extracting data from email (Outlook) to Excel? Outlook VBA and Custom Forms 1
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
J VBA code can't be completely executed in outlook 2013 Using Outlook 0
P VBA Code being completely ignored by Outlook Using Outlook 7
A Accessing .pst folder in outlook using VBA Code Outlook VBA and Custom Forms 4
P 'Trusted' VBA code in Outlook 2003? Outlook VBA and Custom Forms 2
D VBA Code to strip Subject Line when replying or forwarding Using Outlook 3
Z Protecting VBA code - anything new? Outlook VBA and Custom Forms 2
S VBA code to rename a task (flagged message) Outlook VBA and Custom Forms 1
F VBA Code to change subject Like Outlook VBA and Custom Forms 3
Diane Poremsky Pasting VBA code (and other editing) Outlook VBA and Custom Forms 4
S Requried a VBA Code to export Calander details to excel... Outlook VBA and Custom Forms 4
J VBA code to determine 'show' state of SearchBar Using Outlook 7
L Send E-mail with VBA code from [E-mail Distribution Group] if I have “Send as” Using Outlook 6
S Outllok 2007 VBA code to send mail automatically from drafts folder Using Outlook 1
S ThisOutlookSession in VBA not there anymore and code is gone Using Outlook 2
