Permanent line spacing for numbered lists
outl00ker
Is there a way to make this formatting setting permanent? That is, I'd like to have one para spacing between each main point, but the subpoints (a,b,c,d) should not have any spacing. It is rather time consuming to have to manually do the spacing everytime I create the numbered list.
Thanks in advance for your help!
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
cabinet guy permanent response in html Using Outlook 1
T Permanent Removal of RSS feeds folder amd Search folder in Outlook 2010 Using Outlook 10
P Problem in permanent type add-in toolbar Outlook VBA and Custom Forms 6
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
T In-line reply style in Outlook II Outlook VBA and Custom Forms 1
F Auto changing email subject line in bulk Using Outlook 2
R Outlook Working off line Using Outlook 0
D Prompt to prefix subject line whenever sending an email Outlook VBA and Custom Forms 3
R 550 maximum allowed line length is 998 octets, got 1012 Using Outlook 7
2 How to get rid of the "Emailing:" prefix in the subject line Using Outlook 1
O Carriage Return - Line Feeds - exporting Calendar events Using Outlook 0
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
M Convert Subject Line to Internet Header version of Subject Outlook VBA and Custom Forms 10
O Double line spacing - solved with minor drawback Using Outlook 0
N Wide Line Spacing in Folder pane 2016 Using Outlook 18
C Change Subject Line in Selected Emails Outlook VBA and Custom Forms 1
O Adding a new account - "CompanyL (none)" line is added Using Outlook 5
C Outlook - cannot save subject line changes Using Outlook 2
N Select Appointment subject line from combobox or list Outlook VBA and Custom Forms 1
J Marco in search of text in subject line Using Outlook 8
N automatic response with an attachment based on the subject line Outlook VBA and Custom Forms 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
C Outlook Subject Line Macro Outlook VBA and Custom Forms 0
Harald Olsen Automated insertion of address in address line Using Outlook 1
P Can't see full text in From and Subject line Using Outlook 1
D dropdown list in new email in subject line Using Outlook 4
T In-line reply style in Outlook Outlook VBA and Custom Forms 20
N Rename Subject Line with Email Content Outlook VBA and Custom Forms 3
