Email Read and Delete
Hello. I found most of this attached VB code at Mark as read on delete in Outlook?. It was posted by x3ja/Alex (not sure how to give proper attribution here). The comments and the Elseif code are mine. I attached the whole thing to a button on the ribbon. It's purpose is to make deleting emails easier, using a single button instead of 2 moves of the mouse to mark read and delete an email.
Now, this worked just fine with WIN 7 Home 64-bit and Office 2010 32-bit. I have just moved to a new machine with WIN 10 Home 64-bit with the same Office 2010 32-bit.
The macro "works" with a slight difference. For each intended email, 2 iterations of the macro is needed. Tracing it I find that the 2 .Delete methods are NOT effective even though the trace shows the lines executed. For either email object type 2 passes of the entire macro are needed to cause the deletion.
Obviously my question is HUH? What is going on here. All help is appreciated. Sorry, NEVER MIND!!
Well before I sent this I decided to uninstall SPAMBAYES which is open source spam filter software I like. So I uninstalled it and the macro is just fine - only 1 interation to see the intended email go bye-bye. Curious, SPAMBAYES didn't interfere on the Win 7 machine.
So this is a non-problem now. I you want to use the code, feel free.
Thanks for the information. It's definitely weird that spambayes (or any addin) is causing problems.
I was going to ask if you use conversation view and if you turned that off, did it work with one click.
Hi Diane. Until you wrote your note to me I didn't know anything about conversation view. So I found it, realized I didn't use it before, then checked the little radio button, then unchecked it to remain as I was before, then closed Outlook. So the odd macro behavior "seems" to be unrelated to conversation view. A few hours later I reinstalled Spambayes. Since then all is working as desired. I can get back to you in a few days with a status, if you like.
OOPs, I promised a final update but haven't done it. Everything with SpamBayes and Win 10 (64 bit) and Outlook 2010 (32 bit) is perfect. Is there a need to close this ticket?
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
B Move Sent Email to archival pst folder and mark as read - HOW TO Outlook VBA and Custom Forms 2
B Mark copy of sent email as read - VBA? Outlook VBA and Custom Forms 3
V move read email based on date and sender Outlook VBA and Custom Forms 6
M Another way to detect if email read? Outlook VBA and Custom Forms 6
T Some way to capture who marks an email as read Outlook VBA and Custom Forms 1
P SPAM message about Comcast email migration to Yahoo Using Outlook 1
P anything new on the supposed shutdown of comcast.net email? Using Outlook 6
W frustrating trying to change email password Using Outlook 5
R File not found when sending email with attached pdf file Using Outlook 2
U Trouble sending large files to a email group but can to the individuals in that group Using Outlook 8
P Xfinity/Comcast email service stopping sometime in 2025 - warning Using Outlook 8
O Two identical email accounts in Offline Global Address List Using Outlook 2
H Spam email in Gmail not visible in Outlook Using Outlook 3
L Hide Selected Email Address from Address Book Using Outlook 5
Y QQ on Scheduled Delivery of an Email Using Outlook 0
T Replace Text in Email Subject Outlook VBA and Custom Forms 3
Rupert Dragwater Cannot reestablish gmail (email address) account in Outlook 365 Using Outlook 11
M Outlook 365 adding standard message in body of template email Outlook VBA and Custom Forms 3
V iCloud For Windows v15.x - Missing Email Features ? Using Outlook 4
M Thunderbird email client - I wonder Using Outlook 1
D Outlook Desktop App Email Software Using Outlook 0
T Outlook 2010 Creating a email 'Group' in OL 2010 Using Outlook 2
T How to set Default FONT for Email composing ? Using Outlook 0
H Finding text in open email Outlook VBA and Custom Forms 12
A Opening a link from an email automatically Outlook VBA and Custom Forms 0
D Outlook 2021 New email reminder Using Outlook.com accounts in Outlook 1
Rupert Dragwater How do I remove an email ending with @gmail.com Using Outlook 4
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
R Legacy Outlook on Mac Email Cache Using Outlook 0
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 3
H Copying email address(es) in body of email and pasting in To field Outlook VBA and Custom Forms 1
