move read email based on date and sender
V
vbaNEWBIE
Hopefully someone here can help....I would like to move items from my inbox
based on a specific situation. I have the code below for part of it but I
need to add more code to complete it. I am using Outlook 2007 and the code
will run from a Module when initiated by the User.
I would like to move items if meets ALL three conditions:
(1) comes from the Sendername coded below - AND -
(2) the email has been READ - AND -
(3) and the sent date is 14 days old or older
Can anyone help me understand how to modify the code below to accomplish
this ?
Sub MoveItems_Inbox()
Dim myOlApp As New Outlook.Application
Dim myNameSpace As Outlook.NameSpace
Dim myInbox As Outlook.MAPIFolder
Dim myDestFolder As Outlook.MAPIFolder
Dim myItems As Outlook.Items
Dim myItem As Object
Set myNameSpace = myOlApp.GetNamespace("MAPI")
Set myInbox = myNameSpace.GetDefaultFolder(olFolderInbox)
Set myItems = myInbox.Items
Set myDestFolder =
Outlook.Session.Folders("PersonalFolder").Folders("PersonNameFolder")
Set myItem = myItems.Find("[SenderName] = 'PersonName'")
While TypeName(myItem) <> "Nothing"
myItem.Move myDestFolder
Set myItem = myItems.FindNext
Wend
Michael Bauer
Modify the filter like this: [SenderName] = 'x' AND [Unread] = 'false' AND
[SentOn] <= '...'
Please see the VBA help for how to use a date with the Find function.
Best regards
Michael Bauer
Am Tue, 16 Feb 2010 08:45:01 -0800 schrieb vbaNEWBIE:
inbox
code
> this ?
> Set myDestFolder =
> Wend
> End Sub
V
vbaNEWBIE
Thanks Michael - so that I understand I would change it to the following:
Set myItem = myItems.Find("[SenderName] = 'PersonName' AND [Unread] =
'false' AND [SentOn] <= 'DateToMove'")
Did I move the quotation marks correctly ?
Will have to search on using a Date with a Find function.
thanks !
> [SentOn] <= '...'
> > Best regards
> Michael Bauer
> inbox
> code
> > this ?
> > Set myDestFolder =
> > Wend
> > End Sub
V
vbaNEWBIE
Another thought on the Date issue.....is there a way to utilize the Date
function in the filter so that you could use something like If DateReceived <
(Date - 14) Then move to another folder ?
I have used the (Date - 14) within VBA for Excel and it works great and if
this would work it would allow for basically a variable to be used rather
than a specific date. This would be helpful if someone wanted to regularly
run the macro to move emails older than 14 days without having to code it
differently each time.
Thoughts ?
> [SentOn] <= '...'
> > Best regards
> Michael Bauer
> inbox
> code
> > this ?
> > Set myDestFolder =
> > Wend
> > End Sub
Michael Bauer
If the filter isn't as flexible as you need it for the date, filter the
items just for SenderName and Unread. Then loop through the result, read
each item's SentOn property, and do your calculation with it.
Best regards
Michael Bauer
Am Wed, 17 Feb 2010 06:22:02 -0800 schrieb vbaNEWBIE:
DateReceived <
regularly
> Thoughts ?
AND
> > [SentOn] <= '...'
>> > > Best regards
> > Michael Bauer
> > inbox
I
> > code
> >> this ?
>>> Set myDestFolder =
> >> Wend
> >> End Sub
V
vbaNEWBIE
hhhmmmm.....thanks Michael.......what would the code look like for that ? I
am new to VBA with Outlook so I do not have my legs under me yet.
Any suggestions ?
> > Best regards
> Michael Bauer
> DateReceived <
> regularly
> > Thoughts ?
> AND
> >> [SentOn] <= '...'
> >> > >> Best regards
> >> Michael Bauer
> >> inbox
> I
> >> code
> >>> this ?
> >>> Set myDestFolder =
> >>> Wend
> >>> End Sub
Michael Bauer
Date functions in Outlook are the same as in Excel.
Best regards
Michael Bauer
Am Wed, 17 Feb 2010 13:15:01 -0800 schrieb vbaNEWBIE:
I
> Any suggestions ?
>> > > Best regards
> > Michael Bauer
> > DateReceived <
if
rather
> > regularly
it
>>> Thoughts ?
> > AND
> >>> [SentOn] <= '...'
>>>> > >>> Best regards
> >>> Michael Bauer
> >>> inbox
but
> > I
> >>> code
accomplish
> >>>> this ?
>>>>> Set myDestFolder =
> >>>> Wend
> >>>> End Sub
B Move Sent Email to archival pst folder and mark as read - HOW TO Outlook VBA and Custom Forms 2
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 3
B Outlook 2019 Automatically move email after assigning category Using Outlook 4
M Move command Outlook VBA and Custom Forms 11
B Move emails from one account to another Outlook VBA and Custom Forms 2
Commodore Unable to move message Using Outlook 3
J Dopey move - deleted profile Using Outlook 1
Witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 7
M Move to Folder Using Outlook 1
C Can't move folder, the folder is full Using Outlook 0
A Move email items based on a list of email addresses Outlook VBA and Custom Forms 40
T Move calendar invites to new calendar Using Outlook 5
