PDF attachments started to open in Edge
Commodore
Outlook 2021 64 bit
Quite some time ago I read Microsoft was forcing PDF filetype defaults to Edge, and even reversing previously user-set choices. Later on, they apparently "fixed" this back to the (normal) way it has always been.
However, for the last couple of days I've been noticing that PDF attachments in Outlook mail tend to open in Edge. I've rechecked defaults, and PDF is still clearly linked to SumatraPDF on my side (and it opens there when launched from a file manager).
So is this some new wicked tactics to force us using Edge, or just some weird temporary bug? I remember HTML attachments used to behave this way in Outlook (opening in IE instead of some other default browser...).
G Download pdf attachments only if email subject has one of words Outlook VBA and Custom Forms 8
P Printing PDF attachments of Outlook message attachments Outlook VBA and Custom Forms 2
D Save pst and attachments as a PDF File Outlook VBA and Custom Forms 3
J Auto print PDF attachments as they arrive with certain words in subject Outlook VBA and Custom Forms 3
B Outlook 2007 corrupting PDF attachments Using Outlook 4
R File not found when sending email with attached pdf file Using Outlook 2
M Save as Adobe PDF misses inline graphics Using Outlook 0
B Outlook tasks and PDF Using Outlook 4
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 4
X Outlook automation pull from PDF Using Outlook 5
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
Diane Poremsky Save Outlook Email as a PDF Using Outlook 0
B Auto open PDF Outlook VBA and Custom Forms 0
R how to open a pdf file with a known password Outlook VBA and Custom Forms 1
V Emails, pdf.s ocr - oh my Using Outlook 1
E PDF Import Using Outlook 1
J Automatically Print PDF When They Are Received Using Outlook 4
J How to open PDF attachement upon arrivel new mail Using Outlook 20
K Outlook 2010 - sending pdf about 8 MB problem Using Outlook 2
A PDF Attachement Errors with Outlook 2010 Using Outlook 7
L Inserting a PPT/PDF into the message body Using Outlook 1
J Opening a web URL that points to PDF file... Outlook VBA and Custom Forms 7
G pdf format in access 2007 Outlook VBA and Custom Forms 1
W Displaying custom properties of a PDF DocumentItem Outlook VBA and Custom Forms 3
T Emails with attachments from an alias are undeliverable to one of three aliases Using Outlook 2
T Showing Removed Attachments in Thread Outlook VBA and Custom Forms 4
L Outlook attachments from OneDrive as links Using Outlook 0
G Print email attachments when hit subfolder Outlook VBA and Custom Forms 1
KurtLass Opening Graphics Attachments in Outlook 2021 Using Outlook 0
F Outlook 2016 Email with attachments not being received Using Outlook 2
A Attachments.Delete Outlook VBA and Custom Forms 3
