How to prevent corrupted Notes format in Calendar and Contacts
rsbrux
Outlook 365 32 bit
Outlook frequently reformats text in my contacts and calendar entries, reintroducing RTF or HTML *after* I have used the "Clear Formatting" tool. In particular, Outlook arbitrarily removes or inserts line breaks in my Contacts' Notes, with no apparent logic.
Previous threads (like this one) suggest that this is an artifact of synchronization. I am using GWSMO to sync Outlook with Google. Since GWSMO always complains about HTML, I have chosen "Rich Text" as the default under "Outlook Options" - "Mail" - "Compose messages". However, my calendar and contacts also sync with an iPad and an Android smartphone (which use their native apps for them).
How can I stop this reformatting? Is there any solution short of making "Plain Text" the default under "Outlook Options" - "Mail" - "Compose messages"?
O How to prevent image resize when pasting Using Outlook 2
O How to prevent CC from showing when creating a new mail? Using Outlook 1
L OL 2016 contact: is there a way to prevent an admin from mistakenly deleting a contact? Using Outlook 1
D Multiple mailboxes, 1 certificate. How to prevent message "Invalid Certificate" Using Outlook 0
S How to prevent addins Using Outlook 0
Diane Poremsky Prevent Users From Choosing Stationery Using Outlook 0
evdbogaard How to prevent extra line feeds in replies Using Outlook 3
oliv- Prevent copying shared contacts Outlook VBA and Custom Forms 5
oj43085 Prevent Outlook from blocking image from a single source Using Outlook 4
I How to prevent exchange email account from sending emails in Outlook Using Outlook 4
D Prevent Outlook from resolving incomplete contact when clicking send Using Outlook 2
K Prevent meeting requests being sent from a shared calendar in a group mailbox Using Outlook 1
N Prevent reminder dismisal in shared calendar Using Outlook 1
C Security Question - How to prevent users exporting .iaf files Using Outlook 5
B Item_Write = False don't prevent custom form from closing Using Outlook 1
N Allow Another User to Send on Behalf of But Prevent Access to Inbox Using Outlook 4
R Exchange 2010 archive-prevent users moving items direct to archive Exchange Server Administration 1
K How to prevent that Outlook is sending before my add-in is finished? Outlook VBA and Custom Forms 5
K Prevent sending Excel files as attachements Outlook VBA and Custom Forms 1
C Prevent Outlook from sending an email with a blank Subject Line Outlook VBA and Custom Forms 3
A Script to either modify "from" address or prevent a reply being se Outlook VBA and Custom Forms 2
J prevent user from installing wrong version of add-in Outlook VBA and Custom Forms 2
Z Prevent Changes to Custom Form Outlook VBA and Custom Forms 1
kburrows Outlook Classic - JPG files are corrupted when opened or saved Using Outlook 3
K Outlook font corrupted in some point sizes, resets on close/open Using Outlook 2
D Outlook Profiles becoming corrupted Using Outlook 0
G .ost file corrupted / solved the issue with some posts already said, but .ost file is corrupted agai Using Outlook 2
S How to restore corrupted PST file over 2GB in Outlook 2007 Using Outlook 2
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
E Outlook contact group lists corrupted Using Outlook 8
I could not open attached files, i receive a message with “corrupted file” Using Outlook 0
L Outlook 2010 - Keep getting "Corrupted File" Msgs Using Outlook 4
N Outlook 2007 Categories Problem (Most Recentley Used List Corrupted) Using Outlook 3
smokiibear Mobile Contacts Corrupted Using Outlook 3
C crash during account setup - can't delete corrupted account/data file Using Outlook 13
Z PST file corrupted Outlook VBA and Custom Forms 1
B Outlook or iPhone turning tabs into spaces in Outlook Notes Using Outlook 1
P Task display now leaves little room for notes Using Outlook 10
