getSelectedItem does not work in unmanaged Com-Add In
  • Thread starter Thread starter Peter Marchert
P
Peter Marchert
I try to set the default value for a dropdown control in a ribbon.
This is the xml part of the dropdown:
<dropDown id="dropDownControl"
getSelectedItemIndex="CallBackSelectedItemIndex"
onAction="CallBackOnAction"
visible="true"
<item id="dropDownItem0" label="Test1" /
<item id="dropDownItem1" label="Test2" /
<item id="dropDownItem2" label="Test3" /
</dropDown
The callback procedure "onAction" does always work but the
getSelectedItemIndex (same for getSelectedItemID) does not work
correctly.
Here are some examples of the definition for the callback procedure
which works (the message box appears):
Public Sub CallBackSelectedItemIndex(Ctrl As IRibbonControl)
MsgBox Ctrl.id
Public Sub CallBackSelectedItemIndex(ByVal Ctrl As IRibbonControl)
MsgBox Ctrl.id
Public Sub CallBackSelectedItemIndex(ByRef Ctrl As IRibbonControl)
MsgBox Ctrl.id
But if a second parameter is used the message box will not appear. I
tried this combinations:
Public Sub CallBackSelectedItemIndex(ByVal Ctrl As IRibbonControl,
ByRef Index)
Public Sub CallBackSelectedItemIndex(ByRef Ctrl As IRibbonControl,
ByRef Index)
ByRef Index As Integer)
Public Sub CallBackSelectedItemIndex(Ctrl As IRibbonControl, Index)
Public Sub CallBackSelectedItemIndex(Ctrl As IRibbonControl, Index As
Integer)
Long)
Public Sub CallBackSelectedItemIndex(Ctrl As IRibbonControl, ByRef
Index As Integer)
Index As Long)
Index As Byte)
Index As Single)
Index As Double)
Index As String)
ByRef Index As Variant)
I'm using the Office Developer XP to create Com-Add-Ins and designed
it under Microsoft Outlook 2002. To use the ribbons I have implemented
this type library: http://xldennis.wordpress.com/2006/...dalone-type-library-for-iribbonextensibility/
Is it possible that this library is not correct/complete (it is from
2006)?
I worked on this problem now for 2 days and wonder that other users
does not have this problem. Can somebody who uses VB6 try this example
and report if it works with it?
Peter
Dennis's tlb has nothing to do with callback signatures for various ribbon
control callbacks. It has the interface definitions of the ribbon
(IRibbonControl, IRibbonExtensibility and IRibbonUI), that's it. The ribbon
callbacks are controlled and validated by the ribbon schema.
The signature for that callback for VB6/VBA would be:
Sub CallBackSelectedItemIndex(ByVal control As IRibbonControl, ByRef
index As Integer)
"Peter Marchert" <_google@arcor.de> wrote in message
news:230ac3a9-c23d-46fe-98c4-4abeb2c9c181@t13g2000yqt.googlegroups.com...
> Hello,
> visible="true"
> </dropDown
> correctly.
> MsgBox Ctrl.id
> End Sub
> MsgBox Ctrl.id
> End Sub
> MsgBox Ctrl.id
> End Sub
> ByRef Index)
> ByRef Index)
> Integer)
> Long)
> Index As Integer)
> Index As Long)
> Index As Byte)
> Index As Single)
> Index As Double)
> Index As String)
> this type library:
> 2006)?
> Thanks
> Peter
On 12 Aug., 22:04, " - " <kenslo...@mvps.org
Thanks Ken, that saves me the time to create a new one and try it with
this.
> The ribbon callbacks are controlled and validated by the ribbon schema.
I use this one: http://schemas.microsoft.com/office/2006/01/customui
and this works fine e. g. in a normal Excel file.
> index As Integer)
Thank you but also with exactly this definition it will not work.
Seems it has something to do with my develop environment that I cannot
fix. May be this can some one confirm who created an unmanaged Com-Add
In too but the geSelectedItemIndex callback will work fine.
Peter
That's the correct schema to use for Office 2007.
I haven't personally used any ribbon drop-down controls in any of my addins,
managed or unmanaged. I usually don't like the way they work, instead I've
used dynamicMenu controls for what I've had to do.
I'll see if I get a chance today or tomorrow to hack your ribbon code into a
test addin in VB6 I use to play with things and see what happens. I'll let
you know.
news:bdc92058-95a7-45df-82bd-948baf58a27b@g10g2000yqh.googlegroups.com...
this.
> index As Integer)
Peter
On 13 Aug., 15:20, " - " <kenslo...@mvps.org
May be this will do my job too. I will have a look at it, thank you.
> you know.
That would be very kind of you.
Peter
> http://www.slovaktech.com
> "Peter Marchert" <_goo...@arcor.de> wrote in message
> this.
> I use this one:http://schemas.microsoft.com/office/2006/01/customui
> > index As Integer)
> Thanks
> Peter
It looks like the signature that we both found for that callback is for VBA,
not for VB6. For VB6 it's a Function that returns an Integer, not a Sub.
Here is the signature for the callback in VB6, which I tested with my test
addin and which works:
Function GetSelectedItemIndex(control As IRibbonControl) As Integer
See http://msdn.microsoft.com/en-us/library/aa722523.aspx for a complete
list of callback signatures for various languages, including VB6. Make sure
you use those signatures and not the ones for VBA.
news:%23uHZYjBHKHA.4168@TK2MSFTNGP05.phx.gbl...
> addins, managed or unmanaged. I usually don't like the way they work,
> instead I've used dynamicMenu controls for what I've had to do.
> a test addin in VB6 I use to play with things and see what happens. I'll
> let you know.
> > ribbon
> this.
> > index As Integer)
> Thanks
> Peter
On 13 Aug., 16:21, " - " <kenslo...@mvps.org
That's it! Thank you very, very much for your help!
Peter
> Seehttp://msdn.microsoft.com/en-us/library/aa722523.aspxfor a complete
> " - " <kenslo...@mvps.org> wrote in messagenews:%23uHZYjBHKHA.4168@TK2MSFTNGP05.phx.gbl...
> > let you know.
> >news:bdc92058-95a7-45df-82bd-948baf58a27b@g10g2000yqh.googlegroups.com....
> >> ribbon
> > this.
> >> The ribbon callbacks are controlled and validated by the ribbon schema..
> >> index As Integer)
> > Thanks
e_a_g_l_e_p_i Why does MS do these things???? Using Outlook 4
Witzker Outlook 2019 Edit contact from email does not open the user defined contactform Using Outlook 3
J Event/Meeting in Outlook Does Not Align with SharePoint Calendar Using Outlook 5
C Why does Outlook (desktop) 365 for Windows keep making me input my passwords? Using Outlook 12
J WshShell.Popup does't timeout Outlook VBA and Custom Forms 3
L Does this really work and get thru virus and malware blocks? Using Outlook 3
N Free/busy publish at http location does not work Using Outlook 0
Witzker social connector 2010 does not show all emails to or from contact Using Outlook 3
Witzker social connector 2010 does not show all emails to or from contact Using Outlook 0
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
E What does mean this icon at the picture attached? Using Outlook 2
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
C Discovery search does not show autoforwarded messages Exchange Server Administration 1
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
Mark Foley Time span on WebDAV published Calendars does not appear to be working Using Outlook 7
snhnic Macro that does not overwrite but add a number Outlook VBA and Custom Forms 1
Rupert Dragwater Deleting email from Deleted Items does not work Using Outlook 0
G Outlook does not show new appointments in To-Do-Bar Using Outlook 0
G Calendar does not point to deafult data file Using Outlook 0
