RE: Any Fix For Font & Spacing Issues in Outlook 2007?
  • Thread starter Thread starter REFWRVk=
REFWRVk=
Thank you, Maldevane, for your posting! I have tried everything ('cept this,
of course) in order to prevent all the unnecessary spacing around everything.
I have changed my settings in both OUTLQQK 2007 & Word 2007. This will
eliminate a lot of frustration now! Your posting also solved a problem I had
with font type and size.
Thanks, Davey
§ DAVEY §
"Maldevane" wrote:
> Follow these steps in order one by one...
> Open a new message.
> Click 'Format Text' in the tabs at the top.
> Left click on 'Quick Styles' so that it drops down.
> Right click on 'Normal' and choose modify.
> Where it says 'Style for following paragraph' choose 'No Spacing'.
> Then select the radio button below that says 'New documents based on this
> template'.
> Click the little format button near the bottom of the dialog window and
> select 'Paragraph' from the drop down.
> On that new window, make sure line spacing is set to single.
> Make sure the Spacing -> After value is set to 0pt.
> Ensure that there is a check in the box that says 'Don't ass space
> between......'
> Say OK to that window.
> Say OK to the window under it.
> Close that new message.
> Start a new message and try some typing ... did that fix your problem?
> "CatBlue" wrote:
> > Hello all, I hope my note finds you doing well. I have been using Outlook
> > 2007 for about 3 months now and it has been a really tough road. Getting used
> > to all the changes in Microsoft Office 2007 has been a real kick in the head
> > (that bloody ribbon! But I digress). However, using Outlook 2007 is worst of
> > all and has been the bane of my existence.
> > I learned (through this brilliant forum) that I can get rid of double spaces
> > in my emails and signature by pressing Shift-Enter each time I start a new
> > paragraph. As you can imagine, having to do this EVERY TIME is seriously
> > irritating. Every expert says, "Well, just use Plain Text." Alas, then my
> > email is sent to the recipient without the nice, bold font I like (Arial
> > Rounded MT Bold, 11pt in navy) and the wingdings in my signature
> > (symbols/pictures just before my phone, fax, email) do not appear (they are
> > converted to parentheses or numbers).
> > I never had this problem in Outlook 2003. I clicked enter to start a new
> > paragraph and that is what happened; no extra spaces, no extra work doing
> > Shift-Enter. Additionally, 2003 had an option of always using the font I
> > liked to both send and receive messages. It did not matter what the sender
> > used as their font or signature; how I wanted to see my email would override
> > that. I cannot seem to make this stick in Outlook 2007. I get a message that
> > has different fonts and when I click reply, my message will sometimes use
> > their theme and font instead of my default. Sometimes when I click reply the
> > font becomes a microscopic 8pt or 9pt. Absolutely bewildering.
> > What changed between Outlook 2003 and Outlook 2007 to make sending email
> > such a bloody pain? Clearly I am missing something. If anyone has a
> > suggestion or format option that I have overlooked, please chime in.
> > I look forward to your suggestions, kind regards,
> > Cat
It is true that Shift+Enter is the only way to have proper line breaks
in Outlooks HTML editor, but you don't have to type them all manually!
Recently I created a script that remaps the Enter key to the Shift
+Enter combination, whenever the cursor is active within the HTML
editor of Outlook.
The script is free and can be downloaded from the following site:
http://www.fix-outlook-line-breaks.com/
It is based on AutoHotKey.
If you find this solution useful, please consider donating to the non-
profit organization listed on the page above. Thanks!
C Nasty Bug Lurking In Outlook For Years. The Trigger. Any Fix Or Workaround? Using Outlook 12
H How to Fix 1510-370-1986 Garmin GPS Not Working Outlook VBA and Custom Forms 0
C How to fix outlook continuing to prompt fo an Exchange password Using Outlook 0
N May 2017 Fix Didn't Fix? Using Outlook.com accounts in Outlook 6
Micheal Ivan How to fix it ? BCM (Business Contact Manager) 1
J How to Fix “Encounter a large number of conflict items in Exchange OST file” Using Outlook 2
L Outlook 2007 Fix Phone Number Using Outlook 19
Diane Poremsky Fix the Outlook Folder Type after Exporting an IMAP Account Using Outlook 0
P Outlook 2007 Calendar Ribbon has changed and I can't fix it Using Outlook 10
M Outlook hidden even when open (maximising doesn't fix it) Using Outlook 2
P Can't fix my primary email account! Using Outlook 1
B Problem with fix for "Too Many Contact Folders" Using Outlook 3
M Deleted Meeting but didnt send notice to attendees, how to fix?? Using Outlook 1
G fix client/server conversation error message Exchange Server Administration 1
D Email Reminders show up only when in Outlook with Windows 7 - way to fix? Using Outlook 1
P Was Helvetica crashing Outlook, now fix has messed up explorer Using Outlook 4
P fix for Helvetica crasing Outlook 2010? Using Outlook 5
J Wasn't broke, went to fix it, now it's broke! Using Outlook.com accounts in Outlook 0
M Please can someone fix my Outlook Connector sync issue! Using Outlook.com accounts in Outlook 12
D outlook.exe application error - breakpoint has been reached. fix? BCM (Business Contact Manager) 1
P MICROSOFT OFFICE 2007 FREEZING UP HOW DO I FIX ? BCM (Business Contact Manager) 2
F Font Size Using Outlook 3
K Outlook font corrupted in some point sizes, resets on close/open Using Outlook 2
HarvMan Outlook 365 Inbox Font Using Outlook 8
T How to set Default FONT for Email composing ? Using Outlook 0
O Outlook - How to embed font ? (If at all possible) Using Outlook 2
P default font when sending email from browser Using Outlook 1
e_a_g_l_e_p_i Adjusting font size in folders Using Outlook 1
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
M Message list font changed after update Using Outlook 2
P Message List Font Changed Using Outlook 6
