Filter rules to distinguish To and CC fields
  • Thread starter Thread starter Martin Plechsmid
Martin Plechsmid
I have the problem bellow, and was told (in another conference) that I have
to use VBA to solve it. I have two more questions:
1. How do I create a custom filter rule that will execute the VBA function I
create?
2. Will the filter rule run on server, or on (Outlook) client only?
Thank you,
Martin.
"Martin Plechsmid" has written in the news message
news:<uMWnsYgXKHA.4148@TK2MSFTNGP04.phx.gbl>...
> Hello,
> I use Outlook 2007. I need messages with
> To: Helpdesk
> CC: Programmers
> to move to a special folder, while messages
> To: Helpdesk, Programmers
> to leave in the Inbox. How to do that?
> It seems to me that the filter rules do not distinguish between To and CC
> fields.
> Thank you,
> Martin.
Outlook VBA runs on the client only. This kind of procedure can be called by
a rule:
Public Sub WhatEver(Mail as Outlook.MailItem)
' your code here
In the procedure check for the item's To and CC properties, then call its
Move function.
Best regards
Michael Bauer
Am Thu, 5 Nov 2009 16:18:20 +0100 schrieb Martin Plechsmid:
> Hello,
have
I
> create?
> Thank you,
> Martin.
> > Hello,
> > To: Helpdesk
> > CC: Programmers
> > fields.
> > Thank you,
> > Martin.
R unable to filter tasks when start date is on or before today Using Outlook 4
O Filter-Query Builder-Description - what field name to use? Using Outlook 4
Jennifer Murphy Spam filter not working Using Outlook 13
M Filter Conversations - Filter Out Single Emails Outlook VBA and Custom Forms 3
P How to filter primary contacts in business contact manager BCM (Business Contact Manager) 0
G How to filter by the format of an email address Using Outlook 6
S Mail filter recieved before the last 2 working days Using Outlook 1
Liza Creating a rule in outlook to filter messages Using Outlook 0
F Adding textbox filter to listbox? Outlook VBA and Custom Forms 2
Diane Poremsky Filter and Save Contacts to a CSV File Using Outlook 0
Fozzie Bear HomeTab Email filter "Greyed Out" in Outlook 2013 Exchange Server Administration 3
W Filter condition "contains"/"doesn't contain" doesn't always work Using Outlook 10
B Conditional Formatting:How to use >1 value in a filter Using Outlook 7
J Outlook VBA for Email Filter Outlook VBA and Custom Forms 2
Emerogork How do I set up an "Incoming mail filter" Using Outlook 12
M Filter today's mail Using Outlook 2
J Task Filter for Status OR One Month Using Outlook 4
R Filter Views by Category Using Outlook 2
D Junk Mail filter Using Outlook 1
S Filter by accounts but communicate to all linked contacts BCM (Business Contact Manager) 1
D What is this SQL filter that is applied to my Inbox? Using Outlook 6
J Outlook Contacts: How to filter contact phone numbers from a cti request Using Outlook 1
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
D How Would I Write This Filter? Using Outlook 3
N Filter end date works differently in OL'07/OL'10 vs OL'03? Hello?! Using Outlook 12
P BCM Review & Filter BCM (Business Contact Manager) 1
M DASL Filter function? Outlook VBA and Custom Forms 3
M Today(S) function in DASL Filter Outlook VBA and Custom Forms 1
M Create search folder filter that converts UTC time to local? Outlook VBA and Custom Forms 9
E DASL Filter doesn't work when defined programatically Outlook VBA and Custom Forms 1
H Outlook 2007 SQL syntax to filter views of tasks and todo items Outlook VBA and Custom Forms 1
K Can I filter by fields 'containing' specific words? BCM (Business Contact Manager) 1
