BCM Review & Filter
P
P Fruin
I'm trying to send a Markeing Campaign to groups of 30 people at a time - no
particular categorization of these people - just random. So, I Create a List,
click the Review and Filter button, click the Clear All button, select my 30,
press OK and I get a message telling me "You have excluded more than 300
records. Revise your query by using the Simple or Advanced Filter." Neither
of those filters will allow me t do what I'm tying to do either. How do I do
this simple task?
L
Leonid S. Knyshov // SBS Expert
> this simple task?
Don't know, but this sounds like fun. Flagging it for followup. Going to
test this in my lab. Remind me if I don't post a solution by 3/16/10
Leonid S. Knyshov
Try Exchange Online http://bit.ly/free-exchange-trial
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
