RE: Remove +1 and area code from phone numbers
  • Thread starter Thread starter peterm
P
peterm
"Bar JW Farm" wrote:
> I'm sorry to bother you but I am new to Outlook 2003 and cannot fix this
> problem. I have examined the dialing properties in phone and modem settings
> and all looks ok with the area code. I have looked into Outlook's dialing
> options and the automatically add country code is not checked. The problem
> started when I looked up the "check phone number" item on the contact. I
> don't want the +1 or the area code to appear because I sync it with my
> PalmOne.
On Tue, 5 Jan 2010 23:34:01 -0800, peterm <peterm
> > PalmOne.
Haven't used a Palm for a while, but IIRC that option was a Palm setting?
Outlook only adds the country code if you tell it to. If it creates a
problem with your sync software, then the problem is with your sync
software, not Outlook. Outlook follows standard formatting conventions,
which of course it must.
Russ Valentine
"peterm" <peterm> wrote in message
news:09F00B57-A3C7-4142-82E7-4BAA29905A82@microsoft.com...
> > settings
> > problem
> > PalmOne.
Moral of the story: never use the check phone # button. It will screw up the
number formatting.
The dialing options are for dialing, not formatting.
> > settings
> > problem
> > PalmOne.
I have a similar problem. For some reason many numbers have +1 added. Not all.
What is the "never use the check phone # button"? What and where is this? In outlook or in Blackberry?
I have looked in both my Outlook 2010 and my Blackberry Torch 9080 and can not find anything checked to add country code. The instructions above done't lead me to it.
Would appreciate any help.
KuldeepTech How to Remove Multiple Duplicate Outlook PST Files from My Computer? Using Outlook 1
S remove from this device ? Using Outlook 8
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 2
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 0
D Auto Remove [EXTERNAL] from Subject + ConversationTopic (WITHOUT Redemption plug-in) Outlook VBA and Custom Forms 5
Rupert Dragwater How do I remove an email ending with @gmail.com Using Outlook 4
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
Rupert Dragwater How to permanently remove an email address Using Outlook 9
E Remove flag automatically Using Outlook 4
Timmon Remove just one attachment before AutoForward Outlook VBA and Custom Forms 0
Z Remove GMAIL IMAP account from Outlook 2016 Using Outlook 2
O Remove duplicates within two accounts Using Outlook 2
D How to remove a folder, option grayed out Using Outlook 4
B Remove Subject Residual Outlook VBA and Custom Forms 3
R Chancing / remove “ something ” in the subject, online archive Outlook VBA and Custom Forms 8
Morgan Fowler Remove Signature Using Outlook 1
M VBA to remove deferred delivery on a MeetingItem Outlook VBA and Custom Forms 2
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
Diane Poremsky How to Remove RSS Support from Outlook Using Outlook 0
Diane Poremsky Remove Attachments From Messages Using Outlook 0
Diane Poremsky Remove Office 2013 Update Banner Using Outlook 0
O Remove duplicate mail items Outlook VBA and Custom Forms 6
Diane Poremsky Remove a password from an Outlook *.pst File Using Outlook 3
L Fake reminder apperaring (not in calendar) - how to remove? Using Outlook 5
J Your IMAP server wants to alert you to the following: cannot remove system folder Using Outlook 3
C how to remove icons on right hand side outlook 2013 Using Outlook 2
