Form region not appearing on machines I deploy to?
  • Thread starter Thread starter Mark B
Mark B
OL2007, VS2008, C#, VSTO
My form region is not appearing on machines I deploy to even though it
appears fine on the development machine.
http://msdn.microsoft.com/en-us/library/bb386301.aspx#Deploying says:
Deploying a Form Region
Form regions are deployed automatically with the associated Outlook add-in.
Therefore, you do not have to perform any special tasks to deploy a form
region. For more information about deploying add-ins, see Deploying Office
Solutions (2007 System).
Any ideas why it wouldn't be showing up? I've tried on a Vista and an XP
machine.
Is the registration for your form region there? Is it registered for
whatever MessageClass it's supposed to work with?
"Mark B" <none123@none.com> wrote in message
news:O5nQfe9kKHA.2188@TK2MSFTNGP04.phx.gbl...
> add-in. Therefore, you do not have to perform any special tasks to deploy
> a form region. For more information about deploying add-ins, see Deploying
> Office Solutions (2007 System).
> machine.
Yes, I get the setup to add the following key on the target PC:
[HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\FormRegions\IPM.Note]
"MyAddinFormRegion"="=MyAddin"
I checked what it was on my development PC and it was:
"MyAddin.MyAddinFormRegion"="=MyAddin"
So then I manually changed it on the target PC to match the development PC's
key value.
It still didn't show.
What is that registry key doing? Does it point to the location where the XML
for the form region is located? Does the key match the addin ProgID? Usually
if I do a form region I set it up to either supply XML using a location for
the XML in that key, or I supply the ProgID of the class where the form
region is defined. Usually that would be something like MyAddin.Connect.
Also, please put the preceding part of a thread in your reply. It gets way
too hard to follow things if you just snip to your own replies.
news:OVxGGWNlKHA.2164@TK2MSFTNGP02.phx.gbl...
> PC's key value.
The Key value I entered matches the ProgID. If I right-click the add-in
project, select Properties and select the Application tab, the value under
"Assembly name" is the value I used for the Key value. I put an = sign
before it:
=MyAddin
I didn't use any double-quotes.
I would like to test the alternate method of pointing to the location where
the form region XML is but I haven't been able to find it.
I am guessing that the programmer here who first created the form region
used Visual Studio, Right Click, Add New Item>>, Office>>, Outlook Form
Region (template) wizard to automatically create it. It's an adjoining
region that shows below the reading pane. I have looked under the form
region object's .cs, .designer.cs and .resx objects but can't see any
reference to an XML file. Is there one? Do you know where it would reside?
If so what's the best method to reference it?
TIA
news:%232IfKzTlKHA.5820@TK2MSFTNGP06.phx.gbl...
> XML for the form region is located? Does the key match the addin ProgID?
> Usually if I do a form region I set it up to either supply XML using a
> location for the XML in that key, or I supply the ProgID of the class
> where the form region is defined. Usually that would be something like
> MyAddin.Connect.
> > PC's key value.
If the form region was designed inside of VSTO then you usually won't see
the separate XML for the form region, a different type designer is used
then. For VSTO you usually would see the "=MyAddin" type registry entry for
the form region.
You might want to reference the material on form regions at
www.outlookcode.com. There's a lot of information there and links to samples
and posts on the forums there on problems. That might point out something
I'm missing.
news:%23Q4H5GWlKHA.2680@TK2MSFTNGP04.phx.gbl...
> before it:
> =MyAddin
> where the form region XML is but I haven't been able to find it.
> TIA
Thanks Ken. The issue was solved after I posted a question to that forum. I
was referred there to
http://social.msdn.microsoft.com/Forums/en-US/vsto/thread/d0b489c5-5824-40c3-86c4-7cd765f0b56d/.
In that post the following text was relevant:
"I talked to one of the form regions testers about this, and he said that
the value of this key:
ChangeContactsDisplay.MyForm --- REG_SZ --- =ChangeContactsDisplay
needs to match what you used as the folder name [Key Name] in
HKEY_CURRENT_USER/Software/Microsoft/Office/Outlook/Addins to store the
FriendlyName, Description, LoadBehavior, and Manifest registry keys. "
--- <kenslovak@mvps.org> wrote in message
news:%23K%235MCflKHA.2164@TK2MSFTNGP02.phx.gbl...
> for the form region.
> samples and posts on the forums there on problems. That might point out
> something I'm missing.
> > under "Assembly name" is the value I used for the Key value. I put an =
> > sign before it:
>> =MyAddin
> > reside? If so what's the best method to reference it?
>> TIA
A ItemEvents_10_AfterWriteEventHandler is triggers for all instances of the form region Outlook VBA and Custom Forms 1
B Disabling form region change Using Outlook 0
T Outlook replacement form region using a "parent" Outlook VBA and Custom Forms 1
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 3
E Accessing a Form Region from an Inspector Outlook VBA and Custom Forms 3
M Delete key in form region textbox deleting email instead Outlook VBA and Custom Forms 2
M How to change the Title of a form region at runtime? Outlook VBA and Custom Forms 3
M How to read color of form region title? Outlook VBA and Custom Forms 1
M Can I embed ribbon item into form region? Outlook VBA and Custom Forms 2
E Preview of Form Region Outlook VBA and Custom Forms 4
K Accessing contact's custom properties in a Outlook 2007 form region Outlook VBA and Custom Forms 1
R Form Region Outlook VBA and Custom Forms 3
T Form Region Freezing Outlook VBA and Custom Forms 1
V Outlook Form ListBox is not editable Outlook VBA and Custom Forms 2
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
L Applying new form to existing contacts -- MessageClass Outlook VBA and Custom Forms 3
Witzker Outlook 2019 How to get a Photo in a User Defined Contact form Outlook VBA and Custom Forms 2
Witzker Place cursor at opening, a user defined OL contact form Outlook VBA and Custom Forms 2
T Customized form: The Forward option shows write layout Outlook VBA and Custom Forms 0
V Latest Changes to form not appearing for some users Outlook VBA and Custom Forms 3
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 4
V Compound IF, OR, AND in Outlook form Outlook VBA and Custom Forms 4
V Validating Outlook form with "OR" and "AND" Outlook VBA and Custom Forms 1
