Crash when using GetInspector
  • Thread starter Thread starter technomane
technomane
Hello all,
hope you can help me with my problem here. The following code crashes
at line "Set myInspector = myItemb.GetInspector" (Outlook completely
crashes and needs to restart). I have no idea why this happens. From
what I've tried, it only crashes when the macro is started right after
OL startup, while no inspector item was yet launched. When I click on
e.g. "New E-Mail" first (open/close the inspector), it will not crash.
Purpose of the whole thing is to add a user-defined command bar to
every new inspector item (like you would do via "customize" -> "command
bars" -> "macros" menu)
Any help is highly appreciated
Sub DisplayFollowUpBarMenus()
Dim myOlApp As Outlook.Application
Dim myItemb As Outlook.MailItem
Dim myInspector As Outlook.Inspector
Dim cmb As CommandBar
Dim insp As Inspector
Set myOlApp = Nothing
Set myItemb = Nothing
Set myInspector = Nothing
Set myOlApp = CreateObject("Outlook.Application")
Set myItemb = myOlApp.CreateItem(olMailItem)
For Each cmb In myInspector.CommandBars
If cmb.Name = "Followup" Then cmb.Delete
Set cb = myInspector.CommandBars.Add(Name:=Followup, _
temporary:=False, Position:=msoBarTop)
cb.Visible = True
Set cbc = cb.Controls.Add(Type:=msoControlButton)
With cbc
> FaceId = 273
> Caption = "morgen"
> Style = msoButtonIconAndCaption
> OnAction = "FUtomorrow"
With cbc
> FaceId = 273
> Caption = "5"
> OnAction = "FUfivedays"
> BeginGroup = True
myInspector.Display
myInspector.Close (olDiscard)
technomane
If the purpose is only to create the commandbar, use the NewInspector event.
And if the code runs within Outlook, don't call GetObject or CreateObject,
instead use the instrinsic Application object.
Best regards
Michael Bauer
Am Tue, 19 Jan 2010 21:44:59 +0000 schrieb technomane:
> Hello all,
> Next
> cb.Visible = True
> With cbc
> .FaceId = 273
> .Caption = "morgen"
> .Style = msoButtonIconAndCaption
> .OnAction = "FUtomorrow"
> End With
> With cbc
> .FaceId = 273
> .Caption = "5"
> .OnAction = "FUfivedays"
> .BeginGroup = True
> End With
> myInspector.Display
> End Sub
T issue bcm crash when using mousewheel BCM (Business Contact Manager) 7
J Outlook, Word, Access crash unless run in Admin mode - time dependent it seems Using Outlook 10
GregS Immediate crash on opening Using Outlook 3
H How-To recover email from Computer Crash Using Outlook 2
E I have had a total server crash. Exchange Server Administration 2
H Scroll Crash BCM (Business Contact Manager) 2
B Trouble Starting Outlook 2010 after Crash Using Outlook 3
K Outlook Crash on referencing forms Using Outlook 1
B Office 2013: Crash when the E-Mails are sent Using Outlook 3
C crash during account setup - can't delete corrupted account/data file Using Outlook 13
A Major Server Crash - Now Public Calendar Categories Aren't Working! Using Outlook 1
T New Inspector word editor crash Outlook 2003 Outlook VBA and Custom Forms 3
S Business Contact Manager (BCM) causing Outlook crash loop BCM (Business Contact Manager) 3
J BCM -07 Restoration - File Crash BCM (Business Contact Manager) 2
L How do you Recover from An Outlook 2007 & BCM Crash BCM (Business Contact Manager) 1
A COM add-in causes Outlook 2007 to periodically crash where it did not in Outlook 2003 Outlook VBA and Custom Forms 3
R How do I reconnect the database files after a system crash? BCM (Business Contact Manager) 11
