Help - can't get categories to work!
  • Thread starter Thread starter phil baxter
P
phil baxter
Hi all,
I have cobbled together the following code which is triggered by an incoming e-mail event.
It is supposed to automatically add a category to the e-mail (which is the domain name of the sender e-mail).
The script all executes okay, and it appears to be trying to add the right category.
But no categories actually get added.
Any help gratefully received
Phil
Running Outlook 2003, exchange server.
PS. Tried this post on different forum and got no responses at all. Hopefully you lot on here are a bit better!
Public Sub SortByDomain(oMsg As MailItem)
'On Error Resume Next
Dim sDomain As String 'The Sender's domain
Dim oNS As Outlook.NameSpace 'My namespace
Dim oInbox As Outlook.MAPIFolder 'My Inbox
Dim oTarget As Outlook.MAPIFolder 'The domain folder
'If it's not your domain, decipher the domain.
If InStr(oMsg.SenderEmailAddress, "[my domain]") < 1 Then
sDomain = Mid(oMsg.SenderEmailAddress, InStr(oMsg.SenderEmailAddress, "@") + 1)
'Debug.Print sDomain
sDomain = "[my domain]"
Debug.Print sDomain
'oMsg.Categories = oMsg.Categories & "," & sDomain
Dim sSt As String
sSt = "Business"
Debug.Print sSt
AddCat oMsg, sSt
Debug.Print sSt
Public Sub AddCat(itm As MailItem, catName As String)
arr = Split(itm.Categories, ",")
If UBound(arr) >= 0 Then
' item has categories
For I = 0 To UBound(arr)
If Trim(arr(I)) = catName Then
' category already exists on item
' no need to add it
itm.Categories = itm.Categories & "," & catName
' item has no categories
itm.Categories = catName
Debug.Print catName
Your code never calls the itm.Save to make the changes permanent.
Sue Mosher
"phil baxter" <phil[dot]baxter[at]equiteq[dot]com> wrote in message
news:unsn9mBoKHA.1548@TK2MSFTNGP02.phx.gbl...
> Hi all,
> category.
> Phil
> + 1)
> Else
> End If
> Debug.Print sDomain
> Dim sSt As String
> sSt = "Business"
> Debug.Print sSt
> AddCat oMsg, sSt
> Debug.Print sSt
> End Sub
> ' no need to add it
> Exit Sub
> End If
> Next
> Else
> Debug.Print catName
> End If
> End Sub
After setting the Categories property, call itm.Save.
HTH,
JP
On Jan 28, 7:59 am, phil baxter <phil[dot]baxter[at]equiteq[dot]com
wrote:
> Hi all,
> Phil
Thanks, that's perfect. I'm sure I had something similar in earlier code, but must have lost that call.
Again, thanks. This is massively helpful
JP wrote on Thu, 28 January 2010 08:32
> HTH,
> JP
> wrote:
> > Hi all,
> > Phil
