text box length
Alessandro
Hello.
I have a question for you.
Is there a way, programming forms with Outlook 2002, to get a text box
length? I mean, the number of characters in it?
Thank you in advance.
Alessandro
K
Ken Slovak - [MVP - Outlook]
Once you have a handle to the control or any associated Outlook property you
can get the value or text property of the textbox and use the Len() function
to get the length of the control contents.
"Alessandro" <Alessandro> wrote in message
news:9589A5F4-16DB-4567-A206-077EDEFC97B7@microsoft.com...
> Hello.
> Alessandro
Alessandro
Thank you Ken, this is what I was looking for.
I was trying with a Length property...
Another question: what I am doing is this.
I have a text box where I write a text. When I leave the text box and go in
another field, there is a PropertyChange event that write in another text box
the length of the first one.
The question is: is possible to update the second text box directly when
writing in the first one? Without leaving the field?
> > Hello.
> > Alessandro
K
The property won't change until the field is exited. So that event won't
fire until then.
news:0638A1C7-C80F-4B40-8A9F-4171031C5C00@microsoft.com...
> in
> box
T HELP - Send e-mail verification text box Using Outlook.com accounts in Outlook 10
B Passing values from custom form into another form's text box Outlook VBA and Custom Forms 1
Y Setting Text Box to HTML or Rich Text Format Outlook VBA and Custom Forms 3
O Replace hard returns with soft returns on selected text and button to QAT Using Outlook 6
J Outlook 365 Emails showing as links and text only Using Outlook 4
J Text icon in Quick Access toolbar ? Using Outlook 2
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
S Unable to extract text from an Outlook email message Using Outlook 2
T Original email text not shown when replying or forwarding the email. Using Outlook 9
S Outlook to check for specific text Outlook VBA and Custom Forms 3
B Paste formatted text (bold, underlined and in quotes) Outlook VBA and Custom Forms 1
N Is there an Outlook tool to normalize text for entries that are in ALL CAPS? Using Outlook 2
RangerRick Text Extraction from forwarded messages external Exchange Server Administration 1
S Emails Configured As HTML But Sent As Plain Text Using Outlook 13
W Message Text Using Outlook 1
K Update subject based on text in body Outlook VBA and Custom Forms 3
