Installation Issues with Outlook Add-In 2003
  • Thread starter Thread starter Ashutosh Tiwari
Ashutosh Tiwari
I have developed an outlook Add-In using VSTO 2005 for Outlook 2003 which
should and by default also support Outlook 2007 which it is doing correctly.
However when I am trying to install it on the machine with Windows 7 64-bit
and Outlook 2007. It some how giving a error and terminating the
installation.
I have developed this add-in on Windows XP 32-bit version using Visual
Studio 2005.
Any help or suggestion would be appreciated.
What error are you getting? Have you looked at the Fusion logs? You need to
provide more specific information and to do some detective work. For
information on typical problems and Fusion logging see
http://blogs.msdn.com/vsod/archive/2008/04/22/Troubleshooting-com-add-in-load-failures.aspx
"Ashutosh Tiwari" <AshutoshTiwari> wrote in
message news:82B28CB3-202F-46AE-B14B-4DD79E3AE3DB@microsoft.com...
> correctly.
> 64-bit
> installation.
> Studio 2005.
DoctorJellybean Use OST file location for fresh installation? Using Outlook 1
DoctorJellybean Preserve OST file location in new installation? Using Outlook 4
Diane Poremsky How to Uninstall Outlook from an Office Installation Using Outlook 0
N Outlook 2013 installation error Using Outlook 1
icacream outlook 2007 installation file.... Using Outlook 2
P Installation BCM impossible due to untraceable old SQL-server remains BCM (Business Contact Manager) 6
J Need help with installation of BCM in Outlook2013 BCM (Business Contact Manager) 5
V need installation file Using Outlook 5
T I've broken my installation (OL 2013) Using Outlook 0
N Citrix installation possible? BCM (Business Contact Manager) 1
I Post outlook connector installation syndrome - Standby gone Using Outlook.com accounts in Outlook 3
T How to Cancel a queued addon installation on Outlook2003 Launch Outlook VBA and Custom Forms 1
V how to collect details from user, during installation of office addin? Outlook VBA and Custom Forms 1
A Custom Form installation Outlook VBA and Custom Forms 4
Y Outlook 2007 add-in installation problem on Vista Outlook VBA and Custom Forms 1
M VSTO 2007 Addin auto-disabled on one machine but not another on installation? Outlook VBA and Custom Forms 1
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
J BCM Installation problem BCM (Business Contact Manager) 1
J Outlook 2007 with BCM - Out of Memory after MSO12 SP2 installation BCM (Business Contact Manager) 4
R RE: Installation Problem BCM (Business Contact Manager) 3
U looking for feedback on installation process and on eMarking Assis Outlook VBA and Custom Forms 1
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 3
S New Outlook - IMAP ISSUES and support for addins? Using Outlook 1
M Issues with templates - unable to find in old web app Using Outlook 3
Commodore iTunes sync on a new computer - any issues to be expected? Using Outlook 9
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
E Imported Contact Issues Using Outlook 11
D Event ID issues Exchange Server Administration 2
S Outlook.com Sync working, Sync to Android has issues Using Outlook.com accounts in Outlook 1
O Outlook 2016 contact issues Using Outlook 2
J Office 365 and Outlook connection issues Using Outlook.com accounts in Outlook 3
Kris Petorv Calendar issues Using Outlook 0
Diane Poremsky Internet Mail Issues with Outlook Using Outlook 0
Diane Poremsky Mail Issues with Outlook Using Outlook 0
S Outlook 2016 Sync issues with outlook.com Using Outlook 0
