Outlook 2007 add-in installation problem on Vista
  • Thread starter Thread starter Yury
Y
Yury
I've made an Outlook 2007 Add-In using Visual Studio 2005, C#, and VSTO SE.
Unfortunatelly add-in's setup package that working fine in XP environment,
have a problem on Vista.
After successfull installation I found my installation files in 'c:\'
location instead wanted 'C:\Program Files\...\...'.
This happens because Vista permissions issues. If we use 'Run as Admin', the
installation files successfully copied to the destination folder, however the
registry entry for CURRENT_USER is misplaced (instead of logged user the keys
are written for the administrator).
Any suggestions ?
See the information about deploying VSTO addins for all users at
http://www.outlookcode.com/article.aspx?ID=42.
"Yury" <Yury> wrote in message
news:95C7FE0A-E792-42D4-BCF6-630689F52DCB@microsoft.com...
> Hi,
> SE.
> environment,
> the
> the
> keys
> Any suggestions ?
L Outlook 2007 does not start with Apple iCloud-Add-In activated Using Outlook 2
L Outlook 2007 Macro to Add Text to a Contact Field Using Outlook 10
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
A Outlook 2007 add in Outlook VBA and Custom Forms 1
S Outlook 2007 Add-in strange load behavior Outlook VBA and Custom Forms 10
A Add BCM to outlook 2007 BCM (Business Contact Manager) 1
M Will a VSTO C# Outlook 2007 Add-in work on Outlook 2010? Outlook VBA and Custom Forms 1
J how to add Business Contact Manager to existing Outlook 2007? BCM (Business Contact Manager) 2
P Setting combobox properties from Outlook 2007 Add-in Outlook VBA and Custom Forms 9
A COM add-in causes Outlook 2007 to periodically crash where it did not in Outlook 2003 Outlook VBA and Custom Forms 3
J No setup project with Outlook 2007 Add-In project Outlook VBA and Custom Forms 16
C Outlook 2003 Add-in doesn't work on Outlook 2007 Outlook VBA and Custom Forms 1
B Re: Outlook 2003 Add-in doesn;t work on Outlook 2007 Outlook VBA and Custom Forms 2
C Why does Outlook 2007 generate 3 events for 1 single "Add"? Outlook VBA and Custom Forms 6
Q Outlook 2007 Add-in Bug with with Exchange - Long explanation Outlook VBA and Custom Forms 2
