Re: Outlook 2003 Add-in doesn;t work on Outlook 2007
Brian Tillman
"paresh" <paresh> wrote in message
news:575182F8-8E9A-4021-B159-F0364FF69E29@microsoft.com...
> Hi, I wrote Outlook COM Add-in in 2003 using C# and since ages it has been
> working fine in OL2003. We are in process on migrating to OL2007. I found
> that my Add-in doesn't work on OL2007. Could anyone please tell me what are
> the possiblities so that Add-in can't work on OL2007.
microsoft.public.outlook.program_addins would be the correct newsgroup.
Followup set to that group.
C
cGFyZXNo
Could you give me a link to that newsgroup.
Brian Tillman
news:3274268E-73A8-42F0-9070-3C8D200705AD@microsoft.com...
Did you even read the message you quoted? The group name is right there. Or
go to the same page where you found the URL to this group and you'll find a
URL to that one as well. Or you can just click here:
news://msnews.microsoft.com/microsoft.public.outlook.program_addins Or you
can just replace the group name in the URL currently in your web browser,
replacing "general" with "program_addins".
M Outlook 2003 Add-in automated removal Using Outlook 9
A Installation Issues with Outlook Add-In 2003 Outlook VBA and Custom Forms 1
L [Outlook 2003] Add Table to form Outlook VBA and Custom Forms 2
D Why does my Outlook 2003 .Com Add-In disappears after reboot! Outlook VBA and Custom Forms 4
A COM add-in causes Outlook 2007 to periodically crash where it did not in Outlook 2003 Outlook VBA and Custom Forms 3
K 2003 Outlook Contacts - how do I add text to multiple contacts .... Outlook VBA and Custom Forms 2
C Outlook 2003 Add-in doesn't work on Outlook 2007 Outlook VBA and Custom Forms 1
D Wishlist How to use 'app password' in Outlook 2003 after Google pulled plug on "less secure apps" Using Outlook 2
