keep track of the original sender
  • Thread starter Thread starter RWR3YXJk
RWR3YXJk
Hi everybody,
I have written some VBA code to create a work log in Excel and when a user
clicks on a button it exports the sender , date and subject of an email to an
Excel file and when he finishes the job he clicks on another button and sends
a new record to Excel. My code works based on the open or Highlighted email
object so when an operator works on an email request and receives several new
email after that in order to correctly match his worklog records he needs to
go back to original email and highlight it or open it and then click the
"Done" button. My question is : it is possibile to keep track of openning
email ( original request) somehow that when we want to send the "Done" it can
find the original email among hndreds of emails and send a new record to
Excel.
TO restate my question: Is there an efficent way to lets say have a userform
( keeping a list of email that an operator has opend to work on ) and then
the same user can go to that list and select it and send correct info to
Excel file.
My other question would be: if i have a sendr name and email recived date
how can I find the same email object among hundreds of emails ?
I use OL2003 and exchange server 2003
Best regards,
Edward
If you have a reference to an item get the EntryID property, then to
retrieve that item again later use the NameSpace.GetItemFromID() method with
that persisted EntryID value. You can omit the optional StoreID property (it
refers to the mailbox or PST file), or you can get it and use it. To get
StoreID use something like this, where "item" is the selected item:
Dim strStoreID As String
strStoreID = item.Parent.StoreID
item.Parent refers to the folder the item lives in and that object exposes
the StoreID property.
"Edward" <Edward> wrote in message
news:3969A06E-C2E7-476D-B84E-80F059F6B034@microsoft.com...
> Hi everybody,
> an
> sends
> email
> new
> to
> can
> Excel.
> userform
> Excel file.
> > Best regards,
> Edward
Thanks Ken, I'll try that.
Best regards,
Edward
> > Hi everybody,
> > an
> > sends
> > email
> > new
> > to
> > can
> > Excel.
> > userform
> > Excel file.
> > > > Best regards,
> > Edward
Ken,
I'm not an expert in outlook programming , so sorry if i'm asking a trivial
question, I got the EntryID and I keep its value in a modul level string
variable to use it in other procedures later. the problem i have I can only
retrieve it's value once
like
msgbox myNameSPace.GetItemFromID(myID).SenderName
after this code runs and displays the correct data somehow myID variable
which holds the vaure of the EntryId gets cleared and it's value becomes
empty "" so the next time when I run the same code I get an error.
I don't know why this variable dosn't keep the value? any thoughts?
Best regards,
Edward
> > Hi everybody,
> > an
> > sends
> > email
> > new
> > to
> > can
> > Excel.
> > userform
> > Excel file.
> > > > Best regards,
> > Edward
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
V Outlook 2021 Can anyone explain why my Outlook views keep changing?! Using Outlook 2
C Why does Outlook (desktop) 365 for Windows keep making me input my passwords? Using Outlook 12
kburrows Reset Date to Keep Tasks from Archiving Using Outlook 9
T Why is every new email pinned (to keep it on top)? Windows 10 Using Outlook 6
CWM030 Outlook 2016 with imap emails keep Resurrecting themselves? Using Outlook 5
Scorpion New Contacts keep coming up as company Using Outlook 1
R Can't keep emails synced on various devices Using Outlook.com accounts in Outlook 4
piusg 2013: Task Views keep disappearing Using Outlook 4
Dan Badur How can I keep indenting OFF on replies in Outlook 2013? Using Outlook 1
S how to keep "To" when move sent emails to other folder Using Outlook 1
K Deleted emails keep coming back Using Outlook 3
A How to add personal notes to a meeting - and keep them if update sent? Using Outlook 1
A outlook trying to keep sending Using Outlook 1
B Closing Exchange service, how to keep all calendar and mail data? Exchange Server Administration 0
D How to keep Outlook 7 open to full screen Using Outlook 2
S How do I keep my old PST file as default Exchange Server Administration 1
Z Keep Unread Messages in same folder Using Outlook 2
L Oulook always "disconnected" how do I keep it open all of the time? Using Outlook 1
P emails with attachments keep sending... HELP!!! Using Outlook 4
M How do you keep sent emails in the PST folder in outlook 2013 Using Outlook 1
N Contact Groups - names keep changing from Contacts to AddressBook Using Outlook 5
M Reminders keep coming to users' calendar Exchange Server Administration 1
L Outlook 2010 - Keep getting "Corrupted File" Msgs Using Outlook 4
S Reminders keep popping up, even after dismissing them Using Outlook 9
P deleted items keep reappearing in my deleted folder Using Outlook 4
P Stationary and view layout keep changing after reboot? Using Outlook 1
Y MICROSOFT OUTLOOK 2007 - i KEEP GETTING THE "ENTER NETWORK PASSWORD" BOX POPPING UP - IT IS ALREADY Using Outlook 4
A How to keep all conversations expanded? Using Outlook 3
S Deleted messages keep coming back Using Outlook 7
A Keep format of message in the body Outlook VBA and Custom Forms 1
R How do I keep old calendar events from disappearing? BCM (Business Contact Manager) 2
R Outlook 365 How to integrate a third-party app with Outlook to track email and sms? Using Outlook 2
