Reminders keep appearing without being requested
C
CleaningMan
I have just started inputing accounts and contacts into Business Contact
Manager. However after ever entry i get a reminder notice highlighting the
item. It doesn't matter whether i mark the item as closed, or dismiss it, it
keeps re-appearing. As i enter more and more contacts and accounts the
reminder list is growing all the time as i can't get rid of the items. I am
familiar with how to set up reminders and have done that successfully on some
accounts and contacts, but don't understand why i'm geting reminders for
accounts and contacts for which i haven't set a reminder. Even if i go back
to an account and attach a file, i then get a reminder listing the file name
that i attached ! Is there some sort of default setting that keeps bringing
these reminders up ?
Raul Thomas
Did you notice this behavior after install Business contact manager ? or was
is there before as well
Regards
Rahul Thomas [MSFT]
https://blogs.msdn.com/rathomas
"CleaningMan" <CleaningMan> wrote in message
news:FC2B9BBE-F494-4447-B154-39050E0BE731@microsoft.com...
> it
> am
> some
> back
> name
> bringing
Jorge
I get the same reminders.
I setup BCM to share over the network using the Admin Tool. I have gotten
complains from different user about constant reminders that would not go
away. If you try to dismiss all at once, the reminder windows will not
disappear, unless I dismiss each at once. Whether I close the reminders or
dismiss each one separately, the reminders will appear again. I tried looking
at different options to see if anything could trigger them, but I haven't
found anything.
Users did not have this problem before installing BCM.
> > Regards
> Rahul Thomas [MSFT]
Raul Thomas
Hi Jorge
Can you get the user to try the following steps when he /she report the
problem
Download and install MFCMAPI on the affected users box
http://mfcmapi.codeplex.com/Release/ProjectReleases.aspx?ReleaseId=13983
1. Make sure Outlook is closed
2. Using MFCMAPI
3. Open the users profile
4. Choose Business Contact Manager
5. Expand Root Folder
6. Expand Finder
7. Delete the BCMReminders folder
8. Close MFCMAPI
Let me know if this works
Regards
Rahul Thomas [MSFT]
"Jorge" <Jorge> wrote in message
news:1A48335B-7639-4C70-9A77-735D3F88BBAA@microsoft.com...
> looking
> found anything.
> > was
>> > > Regards
>> Rahul Thomas [MSFT]
L
LiamK
I've run through this process once (about a month ago).. and this issue has
now popped up again. I'm getting error now when trying to delete the
BCMReminders folder.
Real question is.. why on earth is this happening in the first place...
seems like a bug to me. I am thinking I should remove the connection between
Accounting 2009 and BCM. This is ridiculous.
> Hi Jorge
> problem
> 2. Using MFCMAPI
> 6. Expand Finder
> 8. Close MFCMAPI
> > Regards
> Rahul Thomas [MSFT]
> > looking
> > found anything.
> >> was
> >> > >> Regards
> >> Rahul Thomas [MSFT]
M Reminders keep coming to users' calendar Exchange Server Administration 1
S Reminders keep popping up, even after dismissing them Using Outlook 9
C reminders not synced by CodeTwo Sync for iCloud Using Outlook 2
T Never-ending Reminders in Shared Calendars Using Outlook 3
A Outlook Reminders not populating for certain events Using Outlook 2
J Are the underlined letters in Outlook Reminders window supposed to work? Using Outlook 4
P Reminders Window stops being displayed, even with /resetfolders or /cleanreminders Using Outlook 8
M Quicken One Step Update Bill Reminders Not Syncing to Outlook Using Outlook 1
J Reminders Display then Disappear Using Outlook 13
G Unable to dismiss reminders from share point list calendar shared in Outlook Using Outlook 2
T populate calendar with appointments and send reminders Using Outlook 1
D Outlook for Android - Dismiss Reminders? Using Outlook 0
M flagged contacts suddenly disappeared from Reminders Using Outlook 3
A Birthday reminders now ending after 10 years?? Using Outlook 4
M Reminders or Notifications for Internet Calendars Using Outlook 1
E Meeting reminders are set for the recipient Exchange Server Administration 9
P Outlook 2013 reminders firing late, in batches Using Outlook 0
Diane Poremsky How to choose which Calendar creates reminders? Using Outlook 0
E Are reminders local or global? Using Outlook 2
D Reminders in Outlook shared calendar Using Outlook 2
Z Reminders for all members of a shared calendar Using Outlook 1
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
PSittner Email Reminders From Excel File Outlook VBA and Custom Forms 6
J Duplicate Reminders Using Outlook 5
D Add tasks to reminders and calender? Using Outlook 1
P open reminders missing after copying outlook pst file Using Outlook 2
A Calendar Reminders are Removed with Sync to Outlook.com Using Outlook.com accounts in Outlook 11
W Midnight bug - Outlook Today & reminders Using Outlook 5
H Calendar entry reminders in Outlook.com Using Outlook.com accounts in Outlook 11
C outlook 2013 task reminders vs. outlook.com task reminders Using Outlook.com accounts in Outlook 8
M suddenly cannot set outlook 2007 contact reminders Using Outlook 2
D OL 13 Reminders Using Outlook 4
J Reminders dismissed on one computer re-appear on Outlook on second computer Using Outlook 1
S No Pop Up Reminders in Outlook 2013 Using Outlook 1
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 0
V Outlook Calendar No Reminders Show up but does on iPhone Using Outlook 2
C shared calendar reminders Using Outlook 6
R How to avoid reminders from delegators' Calendars? Using Outlook 1
A How To Setting Multiple Reminders Using Outlook 1
S Reminders aren't showing up Using Outlook 3
G After syncing with iCould appoinmnet reminders do not show in the to-do bar Using Outlook 9
S Calender reminders question Using Outlook 13
