"Display As" has Gotten Messed up - Question
  • Thread starter Thread starter Marathon
Marathon
Is there a script to make all "Display as" fields just First name last name?
I do not know why but some display as fields show completely wrong names!
TIA
the email display name?
http://www.slipstick.com/contacts/emaildisplayname.htm
first last format would use strFileAs = .FullName
"Marathon" <jsssbs@hotmail.com> wrote in message
news:enCvYKGxJHA.5584@TK2MSFTNGP04.phx.gbl...
> name?
> TIA
Had found this and it worked.
Distribution lists messed up but I will just rebuild them manually I guess.
One more question please Diane?
Why did it insert a blank line in the address field under city and state in
detailed address cards?
"Diane Poremsky [MVP]" <outlookmvp@msn.com> wrote in message
news:ey5HiFHxJHA.988@TK2MSFTNGP05.phx.gbl...
> > name?
>> TIA
Did you try resetting the view to see if they go away? I've only every seen
extra lines like that when I customized the view.
news:eMlDgUHxJHA.4452@TK2MSFTNGP04.phx.gbl...
> Thanks
> guess.
> in detailed address cards?
>> or point
> > your
> >> name?
> >> names!
>>> TIA
Tried that and no effect.
Any other thoughts?
news:OwKYJvHxJHA.1208@TK2MSFTNGP04.phx.gbl...
> seen extra lines like that when I customized the view.
> > Thanks
> > guess.
>>>> or point
> >> your
> >>> name?
> >>> names!
>>>> TIA
So Now I Know why..
The zip code is in the country region field and the country region field
has the zip code in it.
Weird. Don't know how this happened.
Any way to fix this and swap the data in the fields?
> > Thanks
> > guess.
>>>> or point
> >> your
> >>> name?
> >>> names!
>>>> TIA
I don't know of any macros ready to run. Things like this are usually
easiest ot change in Excel - export, swap columns and import.
news:eoFz2PIxJHA.5244@TK2MSFTNGP06.phx.gbl...
> So Now I Know why..
>> or point
> > your
> >> Thanks
> >> guess.
>>>>>> or point
> >>> your
> >>>> name?
> >>>> names!
>>>>> TIA
That's a good idea.
Strange happenings though.
Thanks again!!
news:ua0$JeIxJHA.4364@TK2MSFTNGP03.phx.gbl...
> > So Now I Know why..
>>>> or point
> >> your
> >>> Thanks
> >>> guess.
> >>> state in detailed address cards?
>>>>>>>> or point
> >>>> your
> >>>>> last name?
> >>>>> names!
>>>>>> TIA
OK all those steps seem to have worked!
again and again!!.
news:utvQpjIxJHA.5584@TK2MSFTNGP04.phx.gbl...
> That's a good idea.
> Thanks again!!
>> or point
> > your
> >> So Now I Know why..
>>>>>> or point
> >>> your
> >>>> Thanks
> >>>> guess.
>>>>>>>>>> or point
> >>>>> your
> >>>>>> last name?
> >>>>>> names!
>>>>>>> TIA
Do you know, there is a product called Data Fields Manager for Outlook
(http://www.datafieldsmanager.com) that does a lot of these repetitive tasks?
> Thanks
> again and again!!.
> > That's a good idea.
> > Thanks again!!
> > >> or point
> >> your
> >>> So Now I Know why..
> >>> >>>> or point
> >>>> your
> >>>>> Thanks
> >>>>> guess.
> >>>>> >>>>>> or point
> >>>>>> your
> >>>>>>> last name?
> >>>>>>> names!
> >>>>>>> TIA
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
G Reduce whitespace in Outlook desktop Contact Cards display Using Outlook 3
Witzker Outlook 2019 Display the output of a seach in a new Window Outlook VBA and Custom Forms 6
Albert McCann Outlook 2021 Outlook Display of HTML Email from two senders is glitchy Using Outlook 0
K Daily Task List Minimized Cannot Display Using Outlook 5
J images on note field display fraction of size Using Outlook 5
O After filtering, how to display all events on that day? Using Outlook 4
M All fonts in Outlook emails display with exaggerated character spacing Using Outlook 4
O Tasks - how to display "snoozed" tasks and snooze-times? Using Outlook 7
P Task display now leaves little room for notes Using Outlook 10
R Capture Sender's Display name and Address Outlook VBA and Custom Forms 3
C Why won't Title display in message list? Using Outlook 1
M Daily Task List Minimized Cannot Display Using Outlook 2
C Outlook Mobile app email order randomized and display names stripped Using Outlook 6
N Contact display as Using Outlook 2
J Reminders Display then Disappear Using Outlook 13
O How to display senders email address (column) Using Outlook 1
O How to display number of items per .pst file Using Outlook 7
O Display more months in 'Tasks' Using Outlook 3
O How to display folder icons? Using Outlook 2
Treebys Array out of bounds .display 2016 Outlook VBA and Custom Forms 3
copperberry How to display incomplete tasks due on or before 7 days from now Using Outlook 0
Diane Poremsky Category Color doesn't Display in Inbox Using Outlook 0
P How to make outlook display alert appear on top of other windows whenever a new email is received? Outlook VBA and Custom Forms 1
T Outlook 2016 Calendar multiday event display Using Outlook 4
Diane Poremsky Display the Created Date field of any Outlook item Using Outlook 0
Diane Poremsky Replace Display Names with Email Addresses Using Outlook 0
Diane Poremsky Search for All Messages from Contact and Display in New Window Using Outlook 0
O How to display multi-line task in To-Do List - Outlook 2010 Using Outlook 1
Diane Poremsky Display the Recipient Email Address in the Sent Items Folder Using Outlook 0
Diane Poremsky Excel Files Won't Display in Reading Pane Using Outlook 1
D Display of Open Folders Using Outlook 0
