OL2010 - choosing to not save inline images
Starbuck
In OL2003 and 2010 we can choose to not automatically download linked images when we open HTML e-mail. I like it a lot as it reduces PST size.
Now in v2003 we could open an email outside of the reading pane, get the images, and then close the email item - but the images were not saved into the PST. In v2010, when we get the images the mail item seems to be updated and the images permanently stored inline. Can we change that default behavior back to the way it was?
To reproduce:
Go to Options > Trust Center > Settings.
Check "don't download..." and everything under it.
Now when you get an HTML email with images, in the header you'll see
"Click here to download images..."
Double click the email in the explorer to get an inspector, then download the images.
Now close the inspector.
In OL2003 it asked if you want to save the images but in OL2010 it doesn't anymore.
FWIW, downloading linked imags doesn't affect the pst size - the images are stored in the windows file system.
That it asked about saving changes in Outlook 2003 was a bug - both outlook 2003 and 2010 work the same.
T Outlook 2010 Advice on syncing OL2010 Calendar and Outlook app Using Outlook 0
R OL2010 - Send to Mail Recipient going to wrong account Using Outlook 1
T From OL2010 Pro to OL2003 Pro Using Outlook 4
J Calendar search failing & wrong indexlocation showing..OL2010 Using Outlook 3
K OL2010 Button to Insert First Name Outlook VBA and Custom Forms 6
K OL2010 Button to Insert First Name Using Outlook 1
B OL2010 and install custom WYWO form Using Outlook 1
O Form cache size for OL2010 is set up to 0 Kbs, but sometimes ! Using Outlook 8
R New computer, OL2010 unable to display shared calendar appointments Exchange Server Administration 3
P OL2010 - custom form contact picture Using Outlook 0
B Updating Macro to OL2010/32bit Using Outlook 8
J OL2010 Create a new task while off line Exchange Server Administration 3
M How to skip weekends on recurring appointments - OL2010? Using Outlook 4
R OL2010 Calendar Appointment Highlighting Text issue Using Outlook 3
P migration issue from OL2003 to OL2010 with custom contact form Using Outlook 7
R OL2010; How to ALWAYS Reply/Forward using HTML? Using Outlook 1
B OL2010 - signatures while forwarding tasks or appointments Using Outlook 2
T Can't remove NEW GROUP in OL2010 Using Outlook 1
T Reinstalled OL2010 now have 3 separate inboxes and contacts missing Using Outlook 2
T Defer Sending emails in OL2010 Using Outlook 1
B how to debug in OL2010? Outlook VBA and Custom Forms 3
M OL2007 Add-in won't install on OL2010 Outlook VBA and Custom Forms 1
C Create a Ribbon for the OL2010 Explorer Outlook VBA and Custom Forms 1
Diane Poremsky Choosing the Folder to Save a Sent Message In Using Outlook 0
Diane Poremsky Prevent Users From Choosing Stationery Using Outlook 0
O Choosing Sending Email Address from Word Using Outlook 5
S Choosing different reply template in Outlook 2000 Outlook VBA and Custom Forms 1
R Unable to save complete email to File Explorer Using Outlook 3
J Save Dialog Outlook VBA and Custom Forms 2
M Save as Adobe PDF misses inline graphics Using Outlook 0
Sandgroper48 Save vbaProject Outlook VBA and Custom Forms 2
