How to change all incoming fonts to black?
fcarruth
Great forum but I am still having an Outlook issue. I am new to Outlook 2007 and have a question. Is there a way so that when you receive a reply from a person that their font color is black? It seems to be blue by default. I know how to change it so that all of my replies go out as black but would like it so that all of the replies coming in are black without asking the sender to make the change as well. Is this possible within Outlook or possibly a system wide change within Windows?
Thanks in advance for any help or if I need to clarify a little better.
Frank
When the sender using HTML, you don't have control over the font color. It can't be changed in Outlook or Windows. You could use Read all mail as plain text (It's in tools, Trust Center.) There is a setting in Tool,s Options, Mail format, stationery and fonts where you can tell outlook to use/not use CSS and to use your defaults when possible. This works for some mail but not all email, depending on how it was designed.
Thanks Diane. I'll see if our user will live with that. It works on mine but maybe she wants to see the html coded mail???
Take care.
Frank
Yeah, if she's like me, she'll prefer the HTML format, even on messages that don't really need HTML. I just think its easier on my eyes. HTML newsletters and ads are header to read, but it's easy to switch to HTML per message (look at the info bar).
Danny2015 how to change incoming mail conversationtopic successfully Outlook VBA and Custom Forms 6
W frustrating trying to change email password Using Outlook 5
R Outlook 2021 change view Using Outlook 2
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
C Mass Change Selected Contact Photos Outlook VBA and Custom Forms 1
D Unable to change AppointmentItem.Start property Outlook VBA and Custom Forms 3
sjmo2 Change subject for new e-mails only. Outlook VBA and Custom Forms 2
Horsepower Contact phone numbers randomly change Using Outlook 0
P Outlook 2016 Change Paste Special Default Format Using Outlook 8
whizzard Change FROM address based on TO or CC address Outlook VBA and Custom Forms 8
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
V Can one change the formatting of email title blocks? Using Outlook 0
S Unable to change Message Class Outlook VBA and Custom Forms 0
C Outlook 365 Can you change the follow up colour? Using Outlook 1
O What would be the recommended way to change an email address (family member)? Using Outlook 0
D Change Microsoft Account password - what to do to update on all devices Using Outlook 4
Witzker HowTo Change message Class of contact form Outlook VBA and Custom Forms 0
R How to Change Margins In Google Docs...? Using Outlook 0
D Change senders title Using Outlook 1
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
B Change from Address Outlook VBA and Custom Forms 0
X If you change expiration date of repeated task it dupplicates Using Outlook 1
R Folder pane width change Using Outlook 90
P How can I change my calendar view back Using Outlook 3
T Change the selected Message in the Outlook window Outlook VBA and Custom Forms 2
geofferyh How to change the Attachment File Name? Outlook VBA and Custom Forms 1
