Navigation Pane
LindaState
What can I do to mark emails as read (or at least unbold so they are not "new") when reading them with navigation pane instead of having to double click and open each new message? Thanks!
You can use Ctrl+Q to mark as read or change your settings for the reading pane - or change the reading pane setting to mark as read after xx seconds. My own preference is to use Ctrl+Q so that i have total control over which messages are marked read.
You can also right click on the message in the message list and choose Mark as Read.
to change the reading pane options in Outlook 2007, go to tools, options, other, reading pane.
S Navigation Pane Location And Options Using Outlook 19
Diane Poremsky Outlook's Folder Navigation Pane Disappears Using Outlook 2
D Mail accounts don't show up in navigation pane Using Outlook 1
L Navigation Pane selection with shortcuts Using Outlook 2
T Unexpected change of the order of the folders in my navigation pane Using Outlook 6
T Occasionally, no vertical scroll bar in navigation pane in Outlook 2013 Using Outlook 9
K bcm not showing in outlook 2013 navigation pane BCM (Business Contact Manager) 3
D Views with the ToDo Bar and Navigation Pane Using Outlook 1
J How To Change Font Size For Folder Names on Navigation Pane in Outlook 2013 Using Outlook 1
N Backing Up Navigation Pane Customizations - WinXP Using Outlook 11
A BCM is not in the navigation line BCM (Business Contact Manager) 2
O Outlook 2013 not holding bottom navigation settings Using Outlook 10
M Calendar navigation displays previous field records.check calendar is shared.. Using Outlook 3
M Add small calendar to navigation Using Outlook 1
D.Moore Preview pane question Outlook VBA and Custom Forms 3
D Amazon and some other emails not showing in Preview Pane Using Outlook 10
Z Automatically adjust Outlook Reading Pane from bottom to right depending on portrait or landscape window Using Outlook 1
S Folder Pane Colour Categories Using Outlook 6
bhamberg Shortcuts in Folder Pane (Outlook 2016) Using Outlook 19
B Outlook 365 - Folder pane list clears Using Outlook 28
R Folder pane width change Using Outlook 90
N Wide Line Spacing in Folder pane 2016 Using Outlook 18
GregS What controls content of Folder Pane? Using Outlook 1
A Outlook 2016 Will Not Show Any Data In the People Pane Using Outlook 17
