Rule not working on message headers
ripcurlksm
Do rules work with message headers only? I have an account that gets lots of email and I dont need to download all the message data, so I have it set up to only download message headers.
This rule works with a full message (ive used it many times before), however if the account is only flagged to receive message headers it does not seem to work. Ive tried running the rule manually and these message headers are still sitting in my main Inbox instead of being moved to the specified folder.
Here is my rule:
Apply this rule after the message arrives
through the xxxx@email.com account
and on this machine only
move it to the XXX folder
Any advice? This rule is setup on a laptop I dont always use, and its nice to only download message headers so that I dont have to wait to download 300 MB of email when I try to use outlook on this particular laptop every few months.
B Outlook 2000 Rule to Move txt msg Not Working if size >24KB Using Outlook 3
R Rule not working Using Outlook 5
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 4
CWM330 This rule has a condition that the server cannot process? Using Outlook 1
A rule name into message - how? Outlook VBA and Custom Forms 5
A manual rule sends mail to wrong folder Using Outlook 5
bhamberg Finding a rouge rule... Using Outlook 6
D How to get this rule to work Using Outlook 0
R Rogue Outlook Rule ? Using Outlook 2
L Making rule to move email to folder from one O365 domain Using Outlook 1
