Odd behaviour for auto-receive
USAOz
I have DESELECTED (unticked) the option Send and Receive (under Outlook Options/Advanced) so that email is NOT automatically sent/received (this is to make it work correctly with Mailwasher Pro).
This has worked fine for several years but all of a sudden, this week, whenever I start Outlook - whether from the desktop shortcut, start menu or invoked from within Mailwasher Pro - Outlook always automatically receives my emails. This I do NOT wish to happen!
I have tried uninstalling Mailwasher Pro in case that was the cause but the problem persists. I re-installed and configured Mailwasher Pro but that did not change how Outlook is handling email send/receive.
Any ideas of what may be happening and, more importantly , restore Outlook so that it correctly handles email - i.e. does NOT send/receive until I invoke the Send/Receive option from the Outlook toolbar?
Thanks for any suggestions.
Untick the setting, apply and reset it. That usually fixes problems where a setting is unchecked but not working.
Do you have any addins or applications installed that use outlook data? Something - either an addin or an outlook update - may have affected it.
Thanks for the tip - I'll try it later today and get back to you with the results.
An no, I have no other add-ins or apps that are associated with Outlook.
DB
USAOz
R Outlook 2013 - Odd Sync behaviour Using Outlook 1
V Calendar event acting odd Using Outlook 7
C Odd error message not found in Google search Using Outlook 1
V Odd data file? Using Outlook 5
D This is odd Using Outlook 2
O How do I get rid of odd formatting of new e-mails? Using Outlook 3
C Open message is stuck minimized -Odd behavior when replying to a message(2010) Using Outlook 1
H Odd symbol when stripping characters using vba Outlook VBA and Custom Forms 3
B Strange MAPI/Exchange/IMAP behaviour in OL 2016 under10.0.19044.2006 Using Outlook 0
L Outlook/O365 "sent on behalf" behaviour Exchange Server Administration 1
Ed Sheehan Unusual behaviour in setting Sender (Outlook 2016) Outlook VBA and Custom Forms 4
M Expected behaviour of recurring appointments? Using Outlook 2
Justo Horrillo It's possible to modify the behaviour of the conversation option? Using Outlook 2
wallisellener BCM - Weird behaviour BCM (Business Contact Manager) 20
J Using Group Policy to control Outlook security/attachments behaviour Outlook VBA and Custom Forms 1
T Outlook 2003 Categories behaviour Outlook VBA and Custom Forms 1
S Strange Behaviour of Explorer Object. Outlook VBA and Custom Forms 1
Hornblower409 Hyperlinks - Disable Auto Complete Using Outlook 0
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
D Auto Remove [EXTERNAL] from Subject + ConversationTopic (WITHOUT Redemption plug-in) Outlook VBA and Custom Forms 5
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 3
C New pc, new outlook, is it possible to import auto-complete emailaddress Using Outlook 5
F Auto changing email subject line in bulk Using Outlook 2
