How do I Repair OST File from corruption and Recover OST data?
markjohnson84
Hello guys,
I am in big trouble, as my old .ost file shows error when i open that. Last month, there was some issue with my MS Outlook and it breaks connection with Exchange server. I think that is the reason for my OST file corruption.
Please suggest me any tool/software which can resolve my issue ASAP.
Thanks in advance.
The recommended solution for ost corruption is to delete the ost and let outlook rebuild it. If it continually becomes corrupt, examine the applications that are accessing it - virus scanners etc - and change their settings to skip the ost.
If, for some reason, you'd rather try and rescue the data file instead of creating a fresh copy, See http://www.slipstick.com/problems/pst-repair/repair-a-damaged-personal-folders-pst-file/ for utilities.
SCANOST.EXE (the Integrity check tool) is something which can be used to fix corruption from OST file. It is a built-in utility. Read about it on the Internet.
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
S Repair corrupt .PST & .OST files Using Outlook 5
S Repair Outlook Using Outlook 7
P Recommendation for PST repair program Using Outlook 1
P Outlook 365 Bad experience with KernelAPPS PST Repair program Using Outlook 0
J Outlook 2021 ScanPST errors (yet again ... sorry): repair button missing Outlook 2021 Using Outlook 7
DariTrevino MIcrosoft Outlook PST file cannot repair Using Outlook 1
A ScanPST finding errors but no Repair button Using Outlook 2
J Office 365 - Online Repair vs. Uninstall Reinstall Using Outlook 1
C scanpst.exe doesn't repair .pst file Using Outlook 1
Diane Poremsky Repair a Large Outlook Personal Folders File (over 2GB) Using Outlook 0
Diane Poremsky How to repair a damaged Outlook Personal Folders file (pst) Using Outlook 0
makinmyway ScanPST.exe Missing Repair Button Using Outlook 15
D Trying to repair Outlook rules Using Outlook 5
V pst repeatedly needing repair Using Outlook 2
D pst repair Using Outlook 3
A repair outlook Using Outlook 2
L Outlook repair Using Outlook 1
R MS Office 2010 repair and pst files Using Outlook 2
N Inbox repair tool - scanpst.exe. That file is missing from my computer. Using Outlook 2
W Inbox Repair Tool missing Using Outlook 5
T MSSMLBIZ will not start after a Windows XP Repair BCM (Business Contact Manager) 4
O How will a new Exchange profile handle existing .ost file stored elsewhere? Using Outlook 4
E Gmail folder -why, in .ost IMAP situation, as well as Googlemail folder? Using Outlook 0
J Recover server side rules from OST/PST without access to the server Using Outlook 2
DoctorJellybean Use OST file location for fresh installation? Using Outlook 1
HarvMan Exporting IMAP OST file to PST Using Outlook 5
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
L Restoring Outlook from backup of OST Using Outlook 5
DoctorJellybean Preserve OST file location in new installation? Using Outlook 4
S Moving .OST file location unsuccessful! Using Outlook 6
V Carbonite not backing up .ost files Using Outlook 7
BretAB Connected vs Connected Headers vs OST file. Exchange Server Administration 2
BretAB Connected vs Connected Headers vs OST file. Using Outlook 2
E How to transform .OST in .PST ? Using Outlook 1
C OST email backup Exchange Server Administration 1
