Unified inbox or incoming messages view
Everything's fine, I do have custom views and all the settings... but as I said, as soon as I introduce the "IMAP status equals unmarked" filter, the custom Unified Inbox will go into some sort of infinite Searching loop, with high CPU strain (the CPU fan rpm goes up, so it's audible too :) ...). If I do this on a separate IMAP account's Inbox, it works fine, though.
It seems I won't be needing that filter after all.
I found out that only iCloud's me.com account gives the issues with strike-through on deleted/moved messages (locally). The other two IMAP accounts actually move an item normally into their corresponding Deleted Items folders when deleting, or move to another local folder, not leaving anything in the IMAP's folder on the server.
Not sure if it's a bug -- the only difference is that the me.com IMAP account in Outlook was created a while ago (and the purge-when-switching-folders was on at that time). Perhaps I should try to delete the account and create it anew.
BTW, is there any way to have that Unified Inbox search shown as a folder on the left (in the navigation pane), including the number of unread items (such as is the case with the usual Inbox folder)? Or is this feature not available for "All Mail Items" searches? I know it works with the Search Folders section, but they only work within their corresponding PST files.
Right now I have a shortcut button on Quick Access Toolbar to run the unified inbox search macro.
How about Desktop Alerts (the small windows that slide in from the Windows status bar, showing brief content of new items), should they be working in my case or not? So far it seems they were only working when the default POP3 Inbox/PST was in action; with the IMAP & Unified Inbox setup I have now, all I get is that envelope icon when there are new messages.
Search folders doesn't work for all mail items, only per data file.
Desktop alerts are goofy. They definitely should work for the default account and should work for the secondary accounts in 2010/2013, but its kinda hit or miss with imap accounts, because imap gets the header then the full body and outlook won't always display the alerts.
One more question regarding the unified inbox view... It was carried over to 2013 upgrade without any issues. There is however one difference: It doesn't show RSS feeds. Why is that so?
The search string is "folder:Inbox" and it's set to All Mailboxes. I have a couple of RSS feeds which get delivered to the default Inbox in the defaul local PST file (the one containing tasks and calendar as well). They don't show up (they did in "2010"). Should the code be changed for "2013"?
Well, I left it a couple of hours just to rule out the indexing thing, but the RSS items in the main Inbox are still not displayed. The code for the view is as follows:
Sub UnifiedInbox()
Dim myOlApp As New Outlook.Application
txtSearch = "folder:Inbox"
myOlApp.ActiveExplorer.Search txtSearch, olSearchScopeAllFolders
Set myOlApp = Nothing
M Start Outlook 365 at unified inbox Using Outlook 2
Commodore Unified inbox shows moved messages for a while Using Outlook 4
D Multiple EAS Accounts - One Unified Inbox? Using Outlook 4
C Unified task list Using Outlook 1
J Outlook inbox question Using Outlook 4
F Outlook 2021 Inbox delete icon missing Using Outlook 5
HarvMan Outlook 365 Inbox Font Using Outlook 8
F Inbox moves on taskbar Using Outlook 1
F Outlook 365 Group INBOX by date but not by date and time Using Outlook 1
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
S Format Inbox Using Outlook 0
P Emails assigned with a certain category (within a shared inbox) to be copied to a specific folder. Outlook VBA and Custom Forms 2
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
C Configuring Inbox columns Using Outlook 2
J Collaborative Inbox Using Outlook 1
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
T Inbox Sub-Folder - Web Using Outlook 1
