Screenshots / Clipboard images disappear after sending
vivification
I am running Outlook 2010 x64bit running Windows 8 Pro. (16gig ram)
Everytime I compose a message with a screenshot or image that I pasted from the clipboard, it shows perfectly fine in the message - after I send the message and check the Sent Items - the email doesn't show the pictures at all. And the person receiving the message doesn't get the picture at all either.
This also happens in my signature as well - as my signature has a image in it - but after sending it - it disappears and is blank.
If I resend the email again (go back into Sent Items) - re-paste the image, and resend it sometimes it will then send it.
I cannot for the life of me work out what is causing this.
Reading messages is fine.
I have;
  • Deleted Outlook Temp directory (in Registry)
  • Deleted Temporary Files/Directories
  • Changed Advanced Settings in Internet Explorer
  • Uninstalled & reinstalled Outlook 2010 (Office) + restart
  • Repaired Outlook
What is interesting if I try and use the clipboard manager in Outlook, and try and screenshot something i get the message:
Item not Collected: Larger than Clipboard Capacity.
Does anybody have any suggestions or come across this?
Did it ever work? Is this the only issue you are aware of? I'm thinking it might be winmail.dat issues.
The screenshot error message is because it's high res -
The Office Clipboard may stop adding items even if there are fewer than 24 if you copy large items to it. The Office Clipboard can contain up to 4 megabytes (MB) of data if system RAM is less than 64 MB, or 8 MB if system RAM is 64 MB or greater. To begin copying items again, delete some items or click Clear All on the Office Clipboard. If a single item is larger than 4 MB or 8 MB, you cannot copy the item to the Office Clipboard.
Hi Diane, thanks for the reply.
Positive - it used to to work a while ago. I've just been putting up with it for now.
I've thought about reformatting my machine, but dont want to because I've upgrade from Windows 7 to Windows 8 and its gonna be alot of mucking around to sort it out.
What are the winmail.dat issues you are thinking about?
If a message is sent using RTF formatting and the recipient doesn't use outlook, they get a plain text message and a winmail.dat attachment.
The autocomplete cache remembers the RTF setting (used for meeting requests and voting) and may send all mail as RTF. Delete the names from the autocomplete cache to clear it.
http://www.slipstick.com/problems/outlook-is-sending-winmail-dat-attachments/
K Insert screenshots issue Using Outlook 2
A Clipboard Resize Issue Using Outlook 7
M Retrieve data from GAL and put it in Clipboard Using Outlook 1
Diane Poremsky Paste clipboard contents using VBA Using Outlook 0
F How can i copy the mail subject and the link to the mail to th clipboard? Outlook VBA and Custom Forms 3
R Outlook 2013 VBA I want to put the entire message to clipboard Using Outlook 5
M Clipboard Manager Not showing in Outlook 2010 on Start Using Outlook 8
I Clipboard paste in macro Using Outlook 14
K How to copy Contact Item to Clipboard and Paste as "VCF Link? Outlook VBA and Custom Forms 4
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
J Outlook 365 html inline images Using Outlook 0
J images on note field display fraction of size Using Outlook 5
L Images not displaying in emails sent to self Using Outlook 2
Y Images coming through as Cid:image in outlook Using Outlook 0
S Email Format With Embedded Images and Tables Change Using Outlook 2
M attached images not showing in text area Exchange Server Administration 0
I Outlook on Windows Phone - compressed images .emz Using Outlook 0
H Outlook Images showing as hyperlinks Using Outlook 3
Diane Poremsky Embed Images in New Messages using a Macro Using Outlook 0
Diane Poremsky Import Images into the Active Directory Using Outlook 0
G Linked (online) signature images Using Outlook 5
C images won't display in email Using Outlook 2
D Save downloaded images with the email Using Outlook 2
G Outlook 2013 won't download images Using Outlook 6
R Outlook 2007 not displaying embedded images in emails Using Outlook 1
R conerting links to images Using Outlook 3
G Outlook mailmerge images and images hyperlinks Using Outlook 1
N Outlook refuses to show embedded images on Citrix Windows 2008 R2 Using Outlook 29
D how to display email images when "working offline" Using Outlook 3
T Display of photo images directly within the e-mail message Using Outlook 7
C Problem with Outlook truncating images Using Outlook 6
S OL2010 - choosing to not save inline images Using Outlook 1
A Images Disappear in Outlook 2010 Using Outlook 14
J Internet images embed when pasted in Outlook 2010 Using Outlook 0
D Problem with images not appearing in emails. Using Outlook 14
T Saving Embedded Images in Outlook 2007 Outlook VBA and Custom Forms 3
C Persist the email format and attachments / images while replying A Outlook VBA and Custom Forms 5
